EM TuningChris Nott
Results 1 to 17 of 17
    Sep 2013
    London
    62
    Audi Concert standard Sub problem's....Still not fixed
    My standard Audi sub and rear speakers are not working. Yesterday went to pick up a replacement. He showed me it fully working in the car he was breaking then removed it. I put it in my car today and sub and rears are still not working?? Could it be a problem with the Head Unit. I just want all my speakers to work again. Any help will be appreciated.
    Mar 2012
    295
    First stop is the mini-iso plug on the rear of the HU (assuming it's the ISO not quadlock stereo). What year is the car?
    Sep 2013
    London
    62
    Yep need to buy some radio keys first. Its a 53 plate think first of the 8p'S
    Mar 2012
    295
    Same era as mine (although mine's a little younger) - there are three plugs in the back (unless you have factory bluetooth/phone when it's 4). Two ISO - one for power and earth, one for the speakers (only front on this). One Mini-iso - this has the connections for CAN BUS and the feeds to the amp (for rear speakers and sub) - and CD changer if fiitted.
    Does your radio turn on/off with Ignition? - do you get illumination at night with the radio turned off? - these are controlled by the CAN BUS which is on the same mini-iso as the rear amp.
    Have they ever worked? If they have and if the IGN/Illumination are OK, check for a blown fuse.
    Sep 2013
    London
    62
    Yep my stereo turns on/off with igntion. If i'm listening to radio with ignition off it turns off when pulling out the key. All illuminates as it should. It's never worked since i owned the car. Been through all the fuse boxes there all ok. I just bought some removal keys on ebay so will take it out when they come and go from there.
    Mar 2012
    295
    Er.... Without wanting to state the obvious - the fader's not set fully to the front......
    If the illumination etc works, then the mini - iso is in place, unless it's been butchered at some point
    Sep 2013
    London
    62
    First thing i checked...Gonna have to get some electrical testers out if not.
    sliced's Avatar
    Drive safe, stay alive.
    Jun 2012
    1,161
    Do your rear speakers work properly?
    Current: 8P3 '59 2.0 TFSI 3DR S-Line | Adaptive Bixenons with DLR's | Folding electric mirrors | Heated half leathers |
    Previous : '06 2.0 TDi Sportback in Dolphin Grey| SE | DSG | Satnav | Privacy glass | auto lights | comfort pack |
    Sep 2013
    London
    62
    I changed my whole interior yesterday for half leathers and had the door cards all off. When we took off the drivers side rear doorcard the magnet that sits behind the tweeter fell off. If say one speaker was not working would that cause the sub and other speaker not to work?
    Mar 2012
    295
    Wouldn't have thought a single dead tweeter should bring down the whole thing - although if there's a driect short circuit, it might be shutting down the entire amp via some form of protection.
    sliced's Avatar
    Jun 2012
    1,161
    amp in sub powers rear speakers too, so if rear speakers work might be a loose connection.
    Mar 2012
    295
    Although this is about replacing the sub, it has some useful info on the wiring
    Sep 2013
    London
    62
    Quote Originally Posted by JohnE View Post
    Managed to get the stereo out using some metal nail files haha. I tested the pin that was circled in red on his diagram and its getting 12v. Although my connector for the sub is different i'm gathering the thick red and blue is the live and brown is earth. Tested them with the stereo on and i'm not getting any voltage from that live. I tested it against the another earth just to rule out the brown. So its definatly that red/blue live wire. Just need to find out where that goes!!!!!
    Mar 2012
    295
    That red/blue goes straight back to Fuse 18 in the engine bay box according to the current flow diagram - so if the fuse is good, assume there has to be something disconnected - but I can't see any connectors in the path apart from the 40 pin one at the engine fuse box.
    One other thought - the orange/purple and orange/brown (pin 5 and 6 on the connector) are apparently connections from the rear amp to CAN BUS - I wonder if it's possible to code the car using VCDS to say something like "no sub fitted" - just a thought and purely speculation, but maybe canbus is telling the sub not to bother.
    BTW - you are going to be disappointed when you get this working :-)
    Sep 2013
    London
    62
    Thanks so much JohnE, I went to fuse 18 and for some reason it was missing. Before i checked all the fuses that was in there didnt think of one being missing. Do you know the size fuse for it? Put a 20amp fuse in it for now and got all my sound back. Very Happy!!!
    Mar 2012
    295
    My Haynes manual (!) lists it as 30 amp. Maybe a previous owner needed a fuse urgently and swapped it out as a get you home.
    Glad it's working.
    Sep 2013
    London
    62
    The previous owner had 2 baby's so maybe she got it taken out. Thanks for your help
  1. Very random Audi concert head unit problems
    By beaty33 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th March 2013, 16:09
  2. Audi Concert A3 8L. problem
    By Steven.c in forum In-Car Entertainment
    Last Post: 20th December 2012, 19:33
  3. Emissions warning light......still not fixed!!!
    By RicoS3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st August 2009, 15:45
  4. Audi Concert radio volume knob problems....
    By VAGMAN1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th January 2005, 13:07
  5. A3 1998 with Audi concert II. Possible or not?
    By tennisguy in forum In-Car Entertainment
    Last Post: 17th September 2004, 01:21
