EM TuningJMB Retrofits
    Jul 2013
    16
    what oil should i use and how much/pollen filter question too
    hi guys
    probably been asked millions of times but been a newbie i'll ask again.
    I have a 54 plate (pk54vhx) a3 1.9tdi sportback bkc engine what oil should I use pd? and how much for the service,also I found a old receipt for a pollen filter where does it go if mine is fitted with one.
    thanks
    27,089
    Castrol edge 5w30 usually.
    Pollen filter goes above passenger feet area hidden behind a foam cover & plastic trim that slides to the side then of.
    Jul 2013
    16
    is that a pd oil or do I not need pd oil and how much will I need for an oil change 4/5 litres.
    thanks
    sliced's Avatar
    Drive safe, stay alive.
    Jun 2012
    1,209
    Quote Originally Posted by geordiegooner View Post
    thanks
    4.8L at the top of my head
    Current: 8P3 '59 2.0 TFSI 3DR S-Line | Adaptive Bixenons with DLR's | Folding electric mirrors | Heated half leathers |
    Previous : '06 2.0 TDi Sportback in Dolphin Grey| SE | DSG | Satnav | Privacy glass | auto lights | comfort pack |
    Jul 2013
    311
    I have always used 5 40 Vw quantum oil on all pd Tdi engines ! Also its roughly 4.5 ltrs to the top of the dots on the dip stick if your sumps no been off and removed all the oil
  1. Replies: 13
    Last Post: 19th January 2013, 16:26
  2. what coolant do i use and how much?
    By MR B A3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th August 2011, 13:34
  3. What diagnostics do you use and how?
    By TerryTibbs in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st August 2007, 11:01
  4. What tyres should i use, how big can i go?
    By in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th June 2005, 16:00
  5. whats a drive shaft boot? and how much to replace
    By imported_Yaseen in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th October 2004, 10:23
