AH FabricationsChris Nott
    Sep 2013
    A3 Convertible Boot Wiring Loom
    Hi all,
    I cant find any other posts relating to this, I bought a 2009 A3 convertible recently, and just my luck, after a few days I had a warning on the dashboard that all of the boot mounted lights were broken, and I found I could only open the boot with the key (the electronic lock was previously fine.) After replacing all of the "broken" lights and finding they still didn't work, I've had a bit of a look around, and found that one of the wires that run inside a black rubber protector was totally broken (I'm guessing it got caught in the hinge?) I'm not really technically minded, but I've managed to patch up the wire, albeit outside of the protective sleeve, and it all now works fine. My questions are, has anyone had any experience of this sort of problem? (I've found a few results via Google relating to older models.) And how much should I be looking at to have it repaired?
    Thanks in advance,
    Don.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,491
    yes its a normal thing for them to snap
    same as the a4 cabs
    just make sure you have a good conection and tape it up
    for a repair an auto sparkie will only solder back and tape up so leave as is.
    27,096
    Hey Don, when we do your cruise I can do a repair with solder & heatshrinking if you would like, then I can check the other wires.
    Sep 2013
    Sounds great mate, thanks. Not sure if you got my email?
    27,096
    I did & I will reply
  1. Andi A4 boot spoiler
    By andyer in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th November 2003, 17:32
  2. Wiring loom from S3 (BOSE SETUP)
    By danbrier in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th November 2003, 23:53
  3. Converting Xenons
    By AndrewP in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th October 2003, 12:11
  4. Boot Spoiler
    By stelios24 in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd October 2003, 16:12
  5. Leaky boot
    By skoller in forum Classic Audi Forum
    Last Post: 20th January 2003, 23:32
