AH FabricationsEM Tuning
Results 1 to 9 of 9
Like Tree2Likes
  • 1 Post By NHN
  • 1 Post By NHN
Thread: Brake Pad Warning Light Question
    Feb 2013
    48
    Hi All,
    My brake pad warning light has come on. However, my pads are extremely healthy. There is a little lip on the discs but nothing to be concerned about.
    Any idea why this could be?
    Someone told me it could be the lip cutting through the wire, but I'm not convinced.
    Any ideas?
    LEE69's Avatar
    07 170 DSG
    Jul 2013
    893
    The sensor is usually on the inside pad have you checked them too?
    Growing old is mandatory, growing up is optional
    27,029
    Pads should wear evenly, so I would remove the wheel & check the wiring to see if its been damaged/perished, could be water in a connection aswell, given todays downpours.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,430
    Downpours ?
    Where ?
    LEE69's Avatar
    07 170 DSG
    Jul 2013
    893
    Torquay for one like a monsoon out there.
    27,029
    Yeah Kent, Sussex, Surrey & London had some lovely rain today, as I was in all 4 areas & got soaked whilst doing folding mirror install on an a4 ,which was fun that's for sure, when the doors are stripped & then torrential rain & cant close the windows lol.
    LEE69 likes this.
    manor13's Avatar
    Aug 2013
    West of Lothian
    424
    I had the same turned out the wiring that plugged into the pads was faulty costs a few ££ to fix i believe.
    27,029
    Yeap, repaired the same for a member on here, its a new loom tbh & needs feeding into the bay & cutting old one & soldering/heatshrink so new parts are water tight in arch area.
    The loom comes as pad warning and abs sensor.
    LEE69 likes this.
    Feb 2013
    48
    Thank you
  1. Brake Pad Warning Light?
    By K-Dash in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st April 2011, 22:23
  2. Brake pad warning light wont go off!?
    By mrpies in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd April 2009, 21:47
  3. brake pad warning light
    By avanted in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 13th October 2008, 00:59
  4. brake pad warning light
    By jays3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th September 2008, 10:22
  5. Brake pad warning light reset???????
    By 46TheDoctor in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th April 2007, 08:27
