    Aug 2013
    24
    Audi a3 2.0 fsi P0341
    Hi I'm struggling to figure out what could be causing my audi to read this fault code on diagnostic, engine management light doesn't show up but this fault doesn't seem to go away, iv changed camshaft positioning sensor and have had belt and chain renewed a year back, it reads Camshaft position sensor G40 not a plausible signal P0341 no communication.
    Can anyone help me figure out or have had this fault before please much appreciated?
    Aug 2013
    24
    Could it be a damaged wire due to belt and chain renewed?
    Aug 2013
    24
    Quote Originally Posted by Amir-7-86 View Post
    So many views but not any ideas or advice :/ the g40 code is connected to both knock and camshaft sensor even tho its reading camshaft on the diagnostic, I replaced a new camshaft sensor been told either its damaged or dirty or it could be faulty wiring my guess is when the timing belt and chain had been replaced stress or damage could be caused on the wiring to the sensor, the push down clip on the plug is broken too but plug fits into place anyway, the thing is where to start looking the plug and wiring to me look fine, headache!
    Apr 2013
    Aberdeenshire
    595
    I would check your wiring I assume your car runs if so does it run properly as your timing could be out very slightly and your sensor is telling you this.
    Aug 2013
    24
    Yh it runs, but sometimes itl start first time then at times it may take 2-3 attempts to start, and when its running the rev needle sometimes rev itself not much but up and down slightly only sometimes tho, I thought timing would be out but we checked it with a Audi camshaft locking tool and it fits in could it still be slightly out? The tool is designed to lock the cams in place?
  1. 8P Audi A3 2.0 FSI Sport - Exhaust Upgrade Help
    By josiah2007 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th September 2010, 22:16
  2. Audi A3 2.0 FSI mod advise Pls
    By SneakaFreaka83 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th July 2010, 21:11
  3. Audi A4 2.0 FSi AWA engine. Inlet manifold collapsed !
    By deutscheparts in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd February 2010, 15:00
  4. Has any1 had their Audi A3 2.0 fsi chipped??
    By todd69 in forum General Automotive Chat
    Last Post: 13th January 2010, 00:45
  5. Audi A3 2.0 FSI Sport
    By ronakc in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th March 2007, 09:40
