Badger5Volks Autos
Results 1 to 8 of 8
    Oct 2012
    139
    Radiator Fan (V7) - P1950 - 008 - Movement Restricted / Jammed - Intermittent
    Hi,
    Noticed that my radiator fan seemed to be running more than usual. Did a scan and this came up:
    1 Fault Found:
    006480 - Radiator Fan (V7)
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 0
    Fault Frequency: 49
    Reset counter: 26
    Mileage: 92832 km
    Time Indication: 0
    Date: 2013.07.20
    Time: 14:05:33
    Freeze Frame:
    RPM: 1056 /min
    Torque: 64.0 Nm
    Speed: 1.0 km/h
    0.00 %
    Voltage: 13.45 V
    70.59 %
    Temperature: 91.0°C
    Readiness: N/A
    Cleared the fault just now and it hasn't come back as yet but the radiator fan still seems to be running excessively. Any ideas?
    Had a quick poke around and both fans seem to run freely when turned by hand. It seems to be the big fan on the passenger side that seems to be working hard. The smaller drive side fan wasn't doing anything.
    Is it ok to drive? Should I take it in to be looked at?
    Cheers.
    Jan 2011
    northants
    165
    the fan is faulty
    Oct 2012
    139
    Quote Originally Posted by towcestervag View Post
    the fan is faulty
    Just been reading up on it all.
    I assume since VCDS says the fault was first reported on July the 20th I can drive around until I can book it in to get it fixed?
    Some sites say turning the aircon off can help as it's probably the secondary fan that has gone wrong.
    Oct 2012
    139
    Just went out and started her up. Fan span up like an aircraft engine. Turned off aircon and she calmed down very quickly.
    Can I assume driving around with the aircon turned off is a quick fix until I can get her seen to in a couple of weeks?
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,079
    Have you got two fans or one? I had a similar thing and the little one wasn't working (aircon fan) so the big one was running like the clappers everytime I turned on the aircon.
    Easy fix if its that, my garage took it apart some of the brushes weren't touching sorted that and now it's all good
    A3 Sportback 2.0 TFSI S-Line Quattro Stage 1 Tune it up - Lowestoft Custom Remap- 6187 RPM developing 260 bhp 279lbs ft Akoya Silver, Roof rails, Black heated Vienna Leather, Bose upgrade, Bluetooth
    Oct 2012
    139
    Quote Originally Posted by OVRA3 View Post
    Two fans. Yes the big one is running like the clappers if the aircon is on.
    It's booked in at my local indie on Tuesday. They said on the phone that this is fairly common.
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,079
    If you get them remove the fan unit they will need to grind the back of the smaller fan, clean it all up get the brushes back into place and seal it all up again you should be good to go. No parts required!
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,079
  1. Radiator fans working sometimes
    By shaheed in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th July 2007, 19:36
  2. Question on 2.0tdi sportsback radiator fans
    By JasonM in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th July 2006, 18:56
  3. Radiator Fan
    By rudyno9 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th May 2005, 12:28
  4. Radiator Fan
    By rudyno9 in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th May 2005, 11:33
  5. Audi 90 CS Radiator fans quit
    By jlmata in forum Classic Audi Forum
    Last Post: 2nd June 2003, 15:19
