EM TuningChris Nott
Results 1 to 14 of 14
Like Tree3Likes
  • 2 Post By Sandra
  • 1 Post By Andyc567
Thread: Few Questions Before I Buy An 8P S3
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    Alright guys,
    I've recently just sold my old 8L S3 and I'm now on the hunt for an 8P replacement, thing is looking through the ads there's lots with out the SatNav/DVD headunits and the Flat bottom steering wheels, I'm guessing both of these can be sourced and retrofitted with relative ease?
    but the other main concern is the Arm Rest, again I no they can be sourced and retrofitted but will it be a case of a whole new centre console etc or just simply the Arm Rest and the trims that are associated with it?
    Is it really worth holding out and getting a Facelift version? or are they just cosmetically different like the 8L's were?
    Also any other useful info you can give to me??
    Cheers, Kevin
    Jul 2013
    Southampton
    10
    I have an 07 S3, it seems relatively easy to retrofit SatNav/DVD Headunit and steering wheel as i shall be doing both soon! With the arm rest i think its a new centre console, but i could be wrong! I'm still a newbie when it comes to the S3.
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    14,398
    Kevin, we have site sponsor (NHN) who can supply/fit rnse, steering wheel and armrest. x
    NHN and s3_kev like this.
    Smaller (Local) Events
    Audi-Sport.net online magazine.
    To find Audi-Sport-Net members with VCDS check out the MAP.
    Apr 2013
    26
    With the arm rest you just cut a hole in the top of the console.
    If you do a search you will find plenty of info on it and even the template that you need.
    Original armrest fitting instructions & guide plate A3 2004 ->
    Once the hole has been cut in the console, a mounting stud thing has to be fitted (existing hole I think) and the arm rest is secured to it through the hole left by removing the rear ashtray.
    Mine was fitted by an ex Audi technician, and it only took him 30 mins..
    Sorry to be vague on the fitting, I did watch it being fitted, but it certainly wasn't major surgery so I switched off a bit.
    Hope the info is useful though..
    s3_kev likes this.
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,167
    I've got an 08 S3.. On mine, the cd changer is in the glove box with the main sat nav unit not having a cd slot...
    The only thing that i'm thinking about is that I've got a sharks fin antenna on the rear of my roof and i'm pretty positive thats for the gps, so if you've not got 1, then i'm sure that would need fitted aswell...
    As for the armrest... i've got the sat-nav, leather n alcantara seats with no arm-rest and to be honest I dont need 1..... I'm sure they install into where the rear ash tray is, but dont quote me on that 1
    26,777
    We supply/fit all those parts, so missing tech etc is the least of your worries
    Armrest doesn't need new console at all, just modified to fit.
    TBH facelift version is nicer, I would suggest this, but if you find a very cheap S3 then you could always upgrade it to facelift, but I would try to afford a facelift version.
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,167
    Apart from the jump in around 3 grand between a decent 08 and 58 model
    And personally I think the 8p0 looks better..... more agressive
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    Can you PM me a price for all 3 items so I can see the extra expense for these items prior to going gun hoe and buying an under spec'd s3 and it end up costing more then if I wait for the right car.
    cheers
    Jul 2010
    52
    If I had the choice now I would have kept my 58 8p2 S3. It was much better build quality than the 2011 8P3 BE I bought. It's just turned two and most of the car has been replaced under warranty. (Slight exaggeration but still not as good as the 8P2). My 8P2 had no Sat Nav but did have the FBSW and arm rest. I could easily live without the sat nav and the arm rest.
    Sep 2011
    40
    The armrest is the worst though-out, ill-designed (well apart from zero consideration for a phone installation) contraption that I’ve yet to see in a ‘modern’ car.
    Mine sits in the upright position for all of its life.
    ...making reaching the handbrake marginally better than with it down.
    Not Audi’s best piece of engineering, and clearly an afterthought.
    P.
    PaulAr's Avatar
    S3 (8P)
    Mar 2008
    Tyne & Wear
    4,044
    Quote Originally Posted by kayemill View Post
    Ive had the total opposite experience.
    The 57 Plate I ran for 3 year had numerous warranty issues, clutch, electrical gremlims, glovebox, door drop/seal wear, parcel shelf, window regulators, noisy top mounts....In fact it was a real worry the few months I ran it outside the warranty period.
    The current 12 plater has been sweet as a nut in the last 18month.
    Hopefully I havent spoke too soon.....
    Now:
    -MK2 Golf Gti 16V/VR6, Oak Green, Shrick, Intake, Decat, Kish Retrim, Lenso BSX..
    -BMW 335d Xdrive, Estoril Blue, fully loaded.
    Before:
    S3 (8P), Ibis, DSG, Milltek, SHARK
    BMW 320d M Sport
    S3 (8P), Sprint, REVO, H&R Springs, BBS CHs,
    Golf MK5 GTi 20TFSI - REVO Stage1, Red.
    Golf MK5 GTi 20TFSI - Std, Shadow Blue
    Civic Type `R`
    Golf MK4 GTi 18T - 200bhp, MTM ECU, Forge DV
    Golf MK3 VR6 - Cat Back
    Corrado VR6 - JAMEX
    Corrado G60 - JAMEX, BRM Charger rebuild
    etc....
    PaulAr's Avatar
    S3 (8P)
    Mar 2008
    Tyne & Wear
    4,044
    Quote Originally Posted by perazzi View Post
    P.
    Agree, this is a very low rent part of the car. Cheap and sqeaky. But I still use for leaning on and storing loose change so couldnt really do without it.
    The one in the MK5 Golf is a much beter design, sturdy and more adjustable.
    Now:
    Before:
    BMW 320d M Sport
    Civic Type `R`
    Corrado VR6 - JAMEX
    etc....
    Tolak's Avatar
    Sep 2013
    Somerset, UK
    111
    Quote Originally Posted by PaulAr View Post
    So can teh one for teh golf be fitted to teh S3 (or others)?
    A4 B7 Cabrio 2007 2.0 TDi Black "Sport"
    s3_kev's Avatar
    Stage2'd!!!!!!
    Feb 2008
    1,984
    Agree on the Golf one being a much better design, only problem with the golf is its a better design then the S3
    The arm rests are a big pain for the handbrake agreed but the comfort of having one for all the other time whilst driving to rest on is worth the annoyance of getting to the handbrake imo.
  1. have few questions before i buy any help ?
    By jaysA4 in forum General Chat
    Last Post: 19th August 2012, 16:43
  2. Buying an A3 sportback, few questions before I purchase...
    By dhillon884 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th June 2010, 00:04
  3. Few questions before purchasing
    By boggysv in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th December 2007, 02:29
  4. Buying a A3 Sline TDI soon. Few questions...
    By Mikey in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th November 2006, 20:36
  5. Just about to buy an S3 - A few questions though.
    By paulwakinshaw in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th October 2005, 07:48
