EM TuningAH Fabrications
Results 1 to 16 of 16
Like Tree1Likes
  • 1 Post By tdi-man
Thread: Help, possible fuelling issue with 2.0 TDI BKD
    A3_Adam's Avatar
    Jul 2010
    Hertfordshire/Portsmouth
    62
    Hi all,
    I've recently noticed a strange problem with my 53 reg A3 2.0 TDI BKD 140. When the engine is cold, it has a reluctance to accelerate under load from around 30 mph to 70 mph. It does eventually start to, but after a lot of juddering, as if its not getting enough fuel. The problem disappears once the engine is warmed up but since my journey to work is only around 5 miles it hardly ever reaches 90 by the time I get there.
    I've done a quick search which has pointed towards the tandem fuel pump or injector loom. I also changed the fuel filter last week as it was jet black but the fuel didn't look too full of oil.
    Has anyone ever had similar issues?
    Adam
    Current: A3 2.0 TDI 140
    Mods: Facelift Front, Black Optics Grille, MY09 Rears, HnR lowering springs, Bilstein B4 shocks, Ipod Connection, RS4 Alloys, DTUK Tuning Box
    Link to Build Thread
    M25/South East Monthly Meets
    Sep 2013
    38
    Sorry and dont take this the wrong way but if your engine is cold should you be putting it under load anyway until it's warm? If you drive 10 miles a day is a diesel the right car for you? Related to your problem, have you tried removing the tuning box or temporarily disabling it?
    A3_Adam's Avatar
    Jul 2010
    62
    No worries , I appreciate your input. I removed the tuning box and it made no difference, the problem was still there. Regarding being better off in a petrol, I was thinking the same thing but when I bought the car 3 years ago I was doing around 80 miles a day so it made sense. Also as I'm only on this work placement for another 10 months its not really worth making the switch to petrol.
    I always try to let it warm up before accelerating hard but after 5 mins at 30 mph I have to join a busy motorway so need to get up to speed quite quickly and that's when I notice the hesitation/ juddering.
    Jun 2013
    Norway
    17
    Hi
    Mine has been the same way, when it was cold it seems like it ran in limp mode, after a few mins the car started to respond better.
    Last night i got the throttle changed and cleaned the egr valve, the car runs much better. even tough the check engine light is now on, but this might be a encor or something (i hope=
    tdi-man's Avatar
    Jul 2009
    1,609
    get some good fuel cleaner in the system this may help.
    Diesel Rhino
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs /
    233 bhp - 309 ft lb - 419 nm
    A3_Adam's Avatar
    Jul 2010
    62
    Thanks guys, I'll check out the egr and throttle at the weekend.
    I put some redex injector cleaner in with the last tank of shell and it seemed slightly better at the time. Could have been because it was warmer weather at the time as its only noticeable when its less then 20 degrees outside.
    Sep 2013
    38
    May be worth seeing if someone local to you has VCDS and can help with scanning for any possible fault codes mate! Check the VCDS section
    A3_Adam's Avatar
    Jul 2010
    62
    Just had Gary come do a scan on the car and it came back with the following codes:
    3 Faults Found:
    17668 - PD Unit Injector: Cylinder 1 (N240)
    P1260 - 000 - Implausible Signal
    Freeze Frame:
    RPM: 1764 /min
    Torque: 256.0 Nm
    Speed: 26.0 km/h
    Load: 55.3 %
    Voltage: 14.21 V
    Inj. Quantity: 1.27 mg/str
    Temperature: 45.0°C
    (no units): 16.0
    18074 - PD Unit Injector; Cylinder 1 (N240)
    P1666 - 000 - Electrical Malfunction
    Freeze Frame:
    RPM: 4662 /min
    Torque: 202.0 Nm
    Speed: 39.0 km/h
    Load: 70.2 %
    Voltage: 14.44 V
    Bin. Bits: 00101000
    Temperature: 25.2°C
    (no units): 16.0
    16685 - Cylinder 1
    P0301 - 000 - Misfire Detected - Intermittent
    Freeze Frame:
    RPM: 882 /min
    Torque: 46.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 14.36 V
    Inj. Quantity: 2.96 mg/str
    Temperature: 33.3°C
    (no units): 128.0
    Am I right in thinking its the injector wiring loom that's causing it as it's not consistently misfiring.
    Sportback owner
    Apr 2007
    France
    486
    A bit hard to say if it is an injector fault, or the loom. Perhaps better to change the loom first and see what that brings. If no improvement, then change the injector. Hopefully the loom is the problem, as it has been on many BKD engines. Good luck.
    French A3 Sportback 2006, 2.0L 140 TDI, DSG, RSN-E, Ambient lighting, Auto-lights/wipers, Reverse assist, Dolphin Grey, 17" wheels, Leather seats, Cruise control, Roof bars.
    tdi-man's Avatar
    Jul 2009
    1,609
    2.96 mg/str
    that's not good
    20pricey11 likes this.
    A3_Adam's Avatar
    Jul 2010
    62
    Thanks guys, the Ross-tech site advises to change the harness before the injectors so I think I'll head down to the dealer tomorrow and order one. Does anyone know the part number? Is it 03G 971 033L?
    Oct 2012
    Aldershot, Hampshire
    190
    If it turns out to be the tandem pump let me no. I've got a brand new one sat in my cupboard.
    The injector loom is £90. I ordered one yesterday.
    A3_Adam's Avatar
    Jul 2010
    62
    Well 6 hours later, the new fuel injector and glow plug harness is in, new camshaft cover gasket is in, new tyre is on and car is back together running like a dream.
    Thanks to Gary for coming to scan it with VCDS and thanks to everyone who helped me sort this out:D
    Jun 2013
    Yorkshire
    55
    Hi Adam,
    I have the same issue. Is your car still running OK, did you ever clean out the EGR valve too?
    A3_Adam's Avatar
    Jul 2010
    62
    Hi, a few months on and its still running great. Didn't bother cleaning the egr valve out in the end.
    Jun 2013
    Yorkshire
    55
    I had mine on vagcom, typical though when we did the drive to get data it didn't hesitate! All injector values were ok.. Was yours on off like that?
  1. HELP:possible issue with my central elc modue
    By Rodney5950 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th April 2013, 00:42
  2. Replies: 7
    Last Post: 4th October 2012, 21:41
  3. possible injector issues, any help very much appreciated!!!! a4 tdi 140 bhp
    By chrisk1700 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 4th April 2012, 21:34
  4. Serious help needed!! oil in coolant 2.0 tdi bkd.. Please
    By kdotman in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th February 2011, 23:52
  5. Issues with a3 tdi sportback..........fault codes......please help!
    By vw754 in forum VCDS (formerly VAG-COM) forum
    Last Post: 19th January 2010, 22:59
Tags for this Thread
