Badger5Monster Motorsport
Results 1 to 7 of 7
    Sep 2013
    London
    62
    Electrical Issue with Dashboard brightness and headlight adjuster.
    Both roller type switches on my 2004 a3 don't work. The dash lights are on but dim and the headlight height adjuster does nothing aswell. Where do i start? Would like to test it before buying another set of switches but not sure what wire does what. Could it also be a fuse?
    Any help will be appreciated.
    Feb 2013
    12
    I am also having the same problem.
    Cannot find a blown fuse and have replaced the full switch pack, but to no avail.
    Any help would be greatly appreciated.
    Arron.
    Sep 2013
    London
    62
    So you replaced the switch and there still not working...Mine's most likely gonna be the same then.
    Feb 2013
    12
    Yeah borrowed a switch from a friends car and it didn't work. Put my switch into her A3 and it worked no problems. Did your two rollers stop working at the same time?
    In my case the headlight roller stopped working a long time before the brightness roller did.
    Sep 2013
    London
    62
    I bought the car 2 weeks ago and didnt think to check them. Hope its a simple fix.
    Dec 2012
    236
    I'm also having a similar problem, but basically the dash and console lights don't fail completely, they just fade to the lowest light whenever they want to! If I knock the headlight switch they come back up full and the adjuster works ok again
    any ideas?
    27,096
    Check all wiring & log with vcds.
  1. Replies: 1
    Last Post: 3rd November 2012, 09:57
  2. Issue with colour and finish ....
    By marnie2k in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th March 2011, 19:14
  3. a few issues with my 2.0 tdi (poor mpg and suspected alternator belt tensioner seizin
    By andy16vturbo in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 12th March 2010, 02:18
  4. headlight adjustment up and down
    By dantheman1986 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th July 2007, 22:00
  5. Headlight adjustment with VAGCOM
    By Jamesh in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th March 2007, 20:38
