AH FabricationsVolks Autos
Results 1 to 10 of 10
Thread: Evening all
    Sep 2013
    Evening all
    Hello, im pretty new to this sort of thing i used to own a 300bhp starlet and now have a 04 diesel dsg a3 and i love it got a few extra leather bose all that, im having a few problems with it tho nothing major just after abit of advice, first one is my time clock and mpg resets every few days no idea why :S ? another problem is the car starts on the click of a button when its cold but when its hot it takes its time to start, the battery is fine anyideas?
    cheers
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    In The Sticks....
    2,612
    Quote Originally Posted by el_man View Post
    cheers
    Hot start problem is common, new starter needed.
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    Sep 2013
    I had the car plugged in ny a mate and it comes up cylinder 1 and 4 glow plug electrical fault anyideas? i might throw some glow plugs in
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,621
    Welcome to the ASN mate.
    There are two trip computers, number 1 resets an hour or so after switch off, number 2 only resets when you manually reset it, they're cycled using the button under the wiper stalk. Look for the little symbol in the corner of the DIS to distinguish between the two & it's always best to Read The Manual for details.
    2009 A3 SB 2.0T DSG S line
    Sep 2013
    Will that affect the actual time resetting tho?
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,621
    No, probably not.
    What year\model A3 is it?
    tdi-man's Avatar
    Jul 2009
    1,587
    hot start map may be needed
    cheers
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs / Oil catch can
    233 bhp - 309 ft lb - 419 nm
    FLYWHEEL + HELIX CLUTCH KIT FOR SALE
    Sep 2013
    Quote Originally Posted by Artimus View Post
    No, probably not.
    its a 2004 bkd engine code
    Sep 2013
    more problems with this car i had the flywheel changed because when i accelerate there was a knocking noise, so changed the flywheel and the exact same noise is there? more happens on the motorway any ideas? goes into gear fine and everything, and the second u let go of the throttle there no noise
    Sep 2013
    should i of stuck with my jap motor haha anyideas?
  1. Evening all.... If it came down to it
    By dieselfitter251 in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th June 2009, 19:42
  2. Evening All
    By Blackrat in forum The Welcome Section
    Last Post: 1st May 2009, 22:35
  3. evening all
    By M7R in forum The Welcome Section
    Last Post: 16th September 2008, 10:49
  4. I'M NEW!! EVENING ALL
    By floyd 1.8 turbo in forum The Welcome Section
    Last Post: 11th April 2008, 09:09
  5. Evening All
    By grathies in forum The Welcome Section
    Last Post: 8th June 2007, 00:29
