EM TuningMonster Motorsport
    Jan 2013
    Essex
    100
    ERROR CODES HELP!
    background - my battery died basically and had to replace so it reset some of the ECU (i believe)
    just over a week later my EM light comes on with these 2 error codes -
    P3137 (IMRC) basic setting not carried out
    P3139 Intake manifold runner control deviation
    the light was on and then turned itself off, just worried, could someone please help me with what these mean or what i should do? thanks
    AudiMafia's Avatar
    Apr 2009
    London
    403
    19593/P3137/012599 - Intake Manifold Runner Control: Basic Setting not Completed
    Possible Causes
    • Intake Manifold Runner Control Basic Setting not performed
    Possible Solutions
    • Perform Intake Manifold Runner Control Basic Setting
    Special Notes
    • When found in Engine: 2.0l TFSI
      • Perform Basic Setting.
      • Check TPL 2016420 (RoW)
        • Check Engine Control Module Software Version, if necessary perform Update.
        • Replace Intake Manifold Runner (V157) with updated part.
      • Check TSB 01-08-12 or 2018402 (NAR) North American Region vehicles only.
        • Additional information may be found by searching RVU 24M2 / O3 (Exp. date November 30, 2011) or calling the VW dealer and checking the VIN.
    A3 8P 2.0TDI 140 Sport | Blue | Full Leather Heated Seat | BOSE | 6 Disc Changer | None Smoking Pack | | Nav | Xenons |
    Mods | 18" Rotiform Staggered | Tinted Windows | S3 Spoiler | 2009 S-Line t Rear | Front Chin Spoiler | Wind Deflectors | Re-Map |
    | MY11 Lights | S3 Side Skirts | Private Number Plate | Milltek Exhaust | S Line Gear knob
    AudiMafia's Avatar
    Apr 2009
    London
    403
    19594/P3138/012600 - Intake Manifold Runner Control: Regulation Deviation
    Possible Causes
    • Wiring from/to Intake Manifold Runner Control faulty
    • Intake Manifold Runner Control faulty
    Possible Solutions
    • Check/Repair Wiring from/to Intake Manifold Runner Control
    • Check/Replace Intake Manifold Runner Control
    Special Notes
    • When found in Engine: 2.0l TFSI, perform Basic Setting.
    • When found on Direct Injection engines, such as the 2.0l TFSI, in combination with system too lean or similar faults indicating a vacuum leak diagnose them because "Regulation Deviation " may be the result of a vacuum leak.
    AudiMafia's Avatar
    Apr 2009
    London
    403
    You would need VCDS specific for the basic settings. Check forum faqs and see who has VCDS on your area.
    You need the basic settings done to get rid of the fault codes
  1. Vag-Com error code help/Engine/ABS/Xenon
    By rick28 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th October 2011, 14:52
  2. Error code help please!
    By kev1000 in forum General Technical / How To
    Last Post: 26th September 2011, 13:45
  3. Error Code help
    By fpscod in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th April 2011, 17:53
