Badger5Chris Nott
Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By RobbieWebs
Thread: Can I up the boost by attaching a bleed valve on my Audi 2.0 TDi Quattro
    Jan 2013
    23
    Morning all,
    Is it possible to add a bleed valve to my 2005 Audi A3 TDi Quattro? I think the new turbo isn't set up correctly and with it being a bit of a pig to adjust the actuator on the car I wondered if I could add a bleed valve to it to confirm this is the case. If so where do I add it? I attached it to the vacuum hose that goes to the actuator but this made the car even worse so I have put this back to normal. It's not a permanent add I'm just interested to see if this makes a difference before shelling out money on other parts.
    I will also be attaching a boost gauge to make sure I don't go over the standard pressure.
    Dave
    TDI140's Avatar
    May 2011
    1,364
    I wouldnt reallt f*** with the actuator when your not a turbo specialist or tuner risky business, just take it to someone like midland VW they could do it for you
    A3 2.0TDI FWD sportback with GT1756 250.3bhp 336ft lb, forge boost hoses red, milltek decat system, BMC panel filter, golf gti edition 30 full front brakes brembo pads, black honeycomb grill, full oem s line kit + cupra r lip, LED side lights, OEM xenons, LED interior lighting, LED A8 number plate lights, boost gauge, alloy catch can with red hoses, FBSW, windows tinted, de-badged, now on air ride with chassis notch BBS CH
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,420
    Quote Originally Posted by davidnormanuk View Post
    Morning all,
    Dave
    As below.
    Also...why would you add a bleed valve to the actuator,if not to increase the boost pressure at which it opens the wastegate?,and also as your mod made the car worse,it's quite possible it actually was working properly in the first case.
    Take it to someone who knows how to set things up for you.
    Jan 2013
    23
    I understand peoples worry with regards to setting things up correctly. This is on the list to do but I'm trying to rule out possible faults before I take it somewhere and find out I can replace / repair parts myself. If the actuator is goosed I can replace this myself before taking it to get setup correctly. I am new to the Diesel Scene but I am learning as I go along. I try and do as much research as possible to understand how everything works before going ahead and going mad.
    RobbieWebs's Avatar
    Apr 2013
    Scotland
    751
    Just a quick question but who installed the new turbo for u ?
    Surely if it was a garage they should have set it up for u?
    U can't really skimp with things like these, get it booked in to a specialist and set up properly.
    More expensive in the long run if u end up damaging it.
    Audi A4 BE 2.0 TDI 177 Quattro
    TDI140's Avatar
    May 2011
    1,364
    Turbo should come ready to run but if you went to a random bot well known place then thats probably why its messed up, take it to a well knows garage to sort it out mate
    Jan 2012
    SW London
    794
    I'm fairly certain if u upped the boost the car would just hit limp mode from overboosting anyway. I could be wrong
    2006 Audi A3 2.0 TDI S-Line 8P2 PD170 - Dolphin Grey Metallic - The problem child
    1994 VW Golf VR6 - Mystic Blue - The money thief
    VCDS User
    RobbieWebs's Avatar
    Apr 2013
    Scotland
    751
    Just a thought but if uv put a new turbo in and are going to get it checked over/ set up,why not kill 2 birds with one stone and get it remapped?
    Can't complain of lack of boost then
    TDI140 likes this.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    the actuator on a TDi doesn't work in the same manor as one on a petrol. I'd get the car logged, if boost is meeting requested, it's working. It's more likely your old turbo was overboosting and now you have a working one it feels a bit slower
  1. Will the Exhaust From a 1.8 T S Line 2004 fit a TDI Quattro?
    By shaz in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st September 2012, 08:39
  2. Can I use the Denison ice Link w/Concert II?
    By djoblong in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th December 2004, 09:06
  3. S3 How can you tell the BHP difference???
    By imported_dpo in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th July 2004, 11:54
  4. How high can I raise the power
    By JamesA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th April 2004, 10:05
  5. Why did the boost fail ?
    By rickquattro in forum General Technical / How To
    Last Post: 24th December 2003, 19:33
