Badger5Volks Autos
Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By phil77
Thread: advice needed on esp light then stalling
    Jul 2012
    55
    Hi all been searching for ages today and got a few ideas of what could be causing the fault codes i have, but just wanted to see if anyone had these same issues. So i can save time and money on replacing the right parts first time.
    my problems started when my esp light would show up and then on low idle the car would stall and also as soon as i turn the engine on the fan kicks straight on. These faults are intermittent.
    I have had it plugged in and these fault codes reoccur
    1. mass air flow circuit low input
    2. system too rich off idle bank 1
    3. system too rich off idle bank 2
    I am hoping someone has had the same issues and also is a cheap fix haha cheers all
    sliced's Avatar
    Drive safe, stay alive.
    Jun 2012
    1,217
    What car is it? Age and engine specifics?
    Current: 8P3 '59 2.0 TFSI 3DR S-Line | Adaptive Bixenons with DLR's | Folding electric mirrors | Heated half leathers |
    Previous : '06 2.0 TDi Sportback in Dolphin Grey| SE | DSG | Satnav | Privacy glass | auto lights | comfort pack |
    Jul 2012
    55
    my bad haha 8p 2004 3.2
    sliced likes this.
    Apr 2013
    Aberdeenshire
    592
    Quote Originally Posted by phil77 View Post
    Is it serviced air filter especially and is the throttle body clean and is the battery good.
    sounds a bit like a dodgy maf I would try and disconnect it to see if it runs better.
    Jul 2012
    55
    air filter was recently changed on a service and throttle bodys clean. it wasn't a new one but a different maf was put on and the problem continued
    Apr 2013
    Aberdeenshire
    592
    Does it do it with the maf disconnected your esp light comes on when you disconnect the maf if it wasn't lit before and is your carbon canister clear can you blow through it .
    i kinda think your cts is faulty and maybe would explain your fans and maybe the over fuelling as its possible the ecu doesn't have an accurate reading to regulate fuel trims properly.
    stab in the dark though I would run graphs on vcds
    Jul 2012
    55
    i haven't ran it disconnected and currently not with the car till next week but will try it then. will also get them to run graphs see what shows up. many thanks chillout
    Jul 2012
    55
    mate sent me this morning so gonna start changing parts. start with temp sender
    Apr 2013
    Aberdeenshire
    592
    Maybe it was a good guess then I would also check your earth points behind the headlights especially
  1. esp light then engine management ??? :S
    By finny in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th May 2013, 22:57
  2. Advice needed on rear light
    By Chris-gsxr in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th February 2013, 07:38
  3. advice needed re:ABS / ESP intermittent warning lights
    By gavcav in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th January 2011, 14:05
  4. 2004 3.2 DSG engine stalled ESP light on
    By Marcosline in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th April 2010, 08:21
  5. ESP light then Engine Management light
    By V6Pete in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th March 2010, 08:50
