Sky InsuranceChris Nott
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,067
    Faults codes can't figure it out:
    Hi all,
    The other day cel came on called green flag and the read the fault and it was bank 1 running lean. Cleared it no cel but thought I out to get the car logged to be on the safe side.
    Logs all fine fueling as it should and all seems well.
    Checked for faults today and low and behold bank 1 running lean at idle and now boost pressure regulator not reaching boost.
    Garage have checked the lambda readings and they are normal. I've changed pcv to latest revision and dv to g last year Car is a tfsi running stage 1 .
    Are the codes linked or two separate faults anyone got any ideas?
    A3 Sportback 2.0 TFSI S-Line Quattro Stage 1 Tune it up - Lowestoft Custom Remap- 6187 RPM developing 260 bhp 279lbs ft Akoya Silver, Roof rails, Black heated Vienna Leather, Bose upgrade, Bluetooth
    OVRA3's Avatar
    Jan 2012
    Norwich
    1,067
    On the plus side just retrofitted the come home leaving home lights which worked! Well pleased!
  1. Replies: 4
    Last Post: 4th August 2013, 19:52
  2. 2 Vagcom Fault Codes....Can anyone diagnose / help?
    By LSH in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th October 2012, 00:49
  3. High pitched whistle. Can't figure it out
    By Pipsqueak in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd July 2012, 21:45
  4. Fault codes can anybody help ?
    By macpdm in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st October 2011, 19:53
  5. vag com fault codes..... any help out there please?????
    By shufti in forum VCDS (formerly VAG-COM) forum
    Last Post: 12th March 2007, 03:43
