Volks AutosEM Tuning
Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By NHN
Thread: Fitting the Rear Number Plate
    Jan 2012
    91
    The first job whenever I buy a new car, is a set of number plates, they arrived this morning so promptly took the old ones off. Front first and new plate fitted, slightly off centre but only a few millimetres.
    On to the rear, removed the old plate to find there's a bit of a recess. I don't like having screws on the plate and always opt for the stickers, but there's not a lot of surface area so not sure what to do. I could get a couple more stickers and cover every inch of panel that meets the plate but not sure how good this will be. THe other option is to screw a mounting plate on and then fix the plate to that. Other cars have all been a nice flat surface.
    Any suggestions?
    Jun 2013
    19
    I only ever use the cushioned double-sided tape (comes on a roll), that's recommended for fixing plates... get the right spec with a hi-impact adhesive layer and you should be fine. I'm the same in terms of drilling plates - just seems so wrong.
    26,762
    As above, grab some pads from audi parts departments which are great for plates come on a strip & just build up the area where it would stick, doesn't need the whole recessed area building up, just 2-3 strips & I never drill plates or use screws, looks awful.
    Jan 2012
    91
    Quote Originally Posted by A3_Mayhem View Post
    Is this the stuff? I've only ever needed to use the strips that come with the plates. If it's not thick enough I guess I can just double up to bridge the gap.
    Halfords | Harris Number Plate Tape (12mmx4m)
    Jun 2013
    19
    Looks the ticket.
    One of the review comments says it's quite thin; you might need to use more than one layer to 'build-up' the lower profile areas.
    Jan 2012
    91
    Sorted, cheers!
    Helifella's Avatar
    Flying low level
    Nov 2011
    North Yorkshire
    330
    Follow Helifella On Twitter
    Heavy duty Velcro either side of the indentation does the trick.
    Regards
    HeliFella
    I.A.M. Member http://www.iam.org.uk/about-us/
    '61 spec, A3 Sportback S-Line Black Edition in Ibis White, EM Tuning upgraded LED extended interior XL lightpack,
    Duxback Glass Treatment, Diamond Vision front fog lights, shortened number plates,
    gloss black rear rings & black edition S-line wing badges. Blackvue DR550GW 2 channel in-car camera with Smart Power battery protection.
    Jul 2013
    Cambridgeshire
    215
    Four vertical strips (double sided pad tape) equally distant and mines not budged!
    2007 A3 S Line Quattro 170 TDi
    sliced's Avatar
    Drive safe, stay alive.
    Jun 2012
    1,162
    I've used lots of sticky pads, number plate hasn't fallen off yet! Front ones are screwed on due to curved front.
    Current: 8P3 '59 2.0 TFSI 3DR S-Line | Adaptive Bixenons with DLR's | Folding electric mirrors | Heated half leathers |
    Previous : '06 2.0 TDi Sportback in Dolphin Grey| SE | DSG | Satnav | Privacy glass | auto lights | comfort pack |
    26,762
    If you use the right strips & positioned well, the fronts wont come of even with curve, done it like that for years, also helps to bend the plate beforehand & give it a little bit of shape
    sliced likes this.
    Jan 2012
    91
    All done, got the car out and the gap isn't as big as I'd first thought. Put a strip of the tape all the way round the outside and a double strip in the middle padded out to meet the plate. If the next owner wants to change the plate he's going to have to change the bumper. That plates going nowhere.
  1. Rubber behind the rear number plate
    By Sam_ in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th July 2013, 14:35
  2. Rear number plate LED's x 18 & the law
    By Epson in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th October 2012, 13:19
  3. Replacing the rear number plate on Allroad/Avant (C5 platform)
    By Mudplugger in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 7th May 2010, 10:08
  4. Fixing the rear number plate
    By Dan Yeates in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th March 2009, 16:50
  5. corrosion on the rear number plate light trim.
    By sprally in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st November 2008, 21:05
