Badger5Chris Nott
Results 1 to 8 of 8
    Jul 2013
    104
    Coolant above max level: What adverse effects can this cause?
    I've noticed that my temperature gauge takes, what I believe is an abnormally long time to reach 90. I know what a failed/failing thermostat is like on a 1.8T AUM engine, as suffered one on my old Mk4 Golf GTi and subsequently replaced the stat myself.
    Anyways, after performing a quick visual check of the associated bits n bobs, I've noticed my coolant fluid is above the max fill level. Can this be causing the issue? I know the fluid is hazardous and that the system is pressurised (or at least it should be), so I'm guessing elevated pressure, resulting in cracking or leaks throughout the system could occur, right?
    How should I go about lowering the level? Syphon it out somehow?
    LEE69's Avatar
    07 170 DSG
    Jul 2013
    898
    Noticed my diesel is slow to warm to 90 was warned before i bought it compared to my AUQ Leon.
    Level shouldn't rise, where would the extra come from?
    Syringe to suck some out or a clean rag to soak it up?
    Growing old is mandatory, growing up is optional
    Jul 2013
    104
    Quote Originally Posted by LEE69 View Post
    Not a bad idea.
    The only way there could be excess is if someone overfilled the reservoir. That must've happened while the car was in the hands of it's previous owner. I've only had it a couple of months and probably should've spotted it earlier.
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Of course the level should be checked when the coolant is cold.
    Jul 2013
    104
    Quote Originally Posted by MrLapou View Post
    Understood. I am well versed in the book of Haynes, having performed a thermostat replacement in the past.
    Mar 2011
    Cleveland
    981
    If it doesn't blow coolant out anywhere, forget it!
    Waiting on the Haynes Manual
    Jun 2013
    Dublin
    24
    Shouldn't make a difference, Can't see anything popping cracking or leaking. There's lots of room in the expansion "ball". It would want to get really really hot. and with additional coolant that might take a fraction longer.
    A lot of Garages/mechanics will fill that just over the max line just to allow for settlement after you've run it for a while.
    Apr 2013
    SouthWest
    54
    Agreed, drain off the excess and check the strength of the antifreeze, keep an eye on it. Just one note, you can compress air but not fluid but even if it over pressurised the valve would open. What would worry me is if there is emulsified oil in the water.
    2013 A3 SB 2.0TDI S line, Dakota Grey, Half Leather, Sports suspension, SD card Sat Nav, Cruise control, DAB radio, Audi sound system, Through-load facility, Hold assist, Heated front seats​
  1. What size comps can you put in the front of an A3?
    By ReaperRCJS in forum In-Car Entertainment
    Last Post: 18th April 2008, 10:05
  2. What Audi HU can I fit to a 2001 8L?
    By alijames in forum In-Car Entertainment
    Last Post: 7th March 2008, 14:04
  3. What tyre size can i use?
    By Randomjim in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd February 2008, 15:50
  4. What front brake can I use?
    By clcollins in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd July 2007, 19:34
  5. what offset (et) can i fit?
    By 205man in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th December 2006, 23:58
