Results 1 to 9 of 9
    Apr 2013
    Aberdeenshire
    586
    Slight coolant loss v6
    I have a very slight coolant loss of about 2-3mm under the top line on the expansion tank at cold, I seem to think it fluctuates dependant on ambient some days it's up and other's its down I did pressure test it to 1.5 bar a few months ago with no loss.
    i wondered if it could be down to evaporation as I replaced the radiator a year ago and I can't see any signs of leakage
    does anyone have experience of this ?
    cheers
    26,776
    I have the same issue on a 2.0 tdi, replaced rad & pressure tested, no leaks, next up is IM to check for any leak markings as advised by a mastertech mate, I'll clean the IM whilst its of
    Its annoying me as the car runs perfectly fine, which makes me think its not a head issue, no signs of a leak.
    Apr 2013
    Aberdeenshire
    586
    A mastertech mate eh ? Lucky you I could do with one well even just a mate would be good , with a bit of luck my sisters bf will remember to take a pressure tester home for an overnight test hopefully its not the head as I was concerned about the secondary water pump not running after the audi software update.
    26,776
    lol, yes I expressed the tech bit to advise it came from a good source (mostly) lol.
    I just want to find the poxy leak as its annoying me I cant, arrgghhh.
    Aug 2011
    277
    Had sudden loss of coolant a year ago, unable to find leak so added some stuff Bars or Barrs which I remember using on old 1950's/60's cars. Did the trick though as no loss since.
    Apr 2013
    Aberdeenshire
    586
    Under pressure just now at a bar or 14.7 psi if your metric thinking it might be the head hope not though but I can't see traces I would prefer it to be the matrix .
    Apr 2013
    Aberdeenshire
    586
    Quote Originally Posted by Chillout View Post
    It held pressure overnight however I don't think the matrix was pressurised as the climate valves were shut from google it looks like it is a twin port valve that isolates both the flow and the return does any one have experience of this as its a big strip down to prove .
    26,776
    Didn't know there was a valve for this, I have a whole heater unit somewhere here, so will check if it has valves on the coolant circuit.
    Apr 2013
    Aberdeenshire
    586
    I think it must have valve like a zone valve on you heating at home ,I had one solenoid stick on heating I was sweating like a celebrity!
    Ok not a well known one as it was a fiesta.
    I think it would look similar to this thanks to google
  1. A4 TDI no power when cold and slight coolant loss
    By lukefaichney in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 26th June 2012, 11:45
  2. my coolant loss story
    By Lex in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd March 2009, 12:42
  3. Coolant Loss! 1.8T
    By jcp in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th May 2008, 22:43
  4. Coolant loss changing Thermostat?????
    By S3 Dave in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st November 2007, 22:43
  5. 2.0 TDi Coolant loss <again> - Get it checked out!!
    By adamhill in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th August 2006, 16:20
