Sky InsuranceEM Tuning
Results 1 to 11 of 11
    Sep 2013
    38
    Warm/hot start issue
    Afternoon all,
    I've recently purchased an Audi A3 2.0 tdi, MY2004. Whilst I love the car and have been very impressed with it, it has a problem. I have spent literally hours researching this and wondered if anyone could provide more detailed info
    When my car is cold fist thing in the morning it starts almost instant with no hesitation. As soon as the water temperature goes above 70ish, if the engine is turned off, upon restarting it will take a good 3-4 seconds of cranking for the engine to restart.
    Now I've read all kinds of stories, does anyone know the most likely cause of this issue? Any helpful posts will be extremely appreciated
    Thanks in advance
    LEE69's Avatar
    07 170 DSG
    Jul 2013
    898
    For when your starter doesn't reach the correct RPM and no fuel is available
    Creating fuel at lower Cranking RPM will temporally solve the problem
    Failing starter or failing battery causes it.
    I asked this the other day elsewhere when i read about the problem
    Growing old is mandatory, growing up is optional
    Sep 2013
    38
    Can it be "remapped" out? Or is there a software update available for it ? If so who can do this?
    LEE69's Avatar
    07 170 DSG
    Jul 2013
    898
    Yeah a remap can sort it, not sure of a software update?
    tdi-man's Avatar
    Jul 2009
    1,612
    needs to be mapped out
    check vag com for fault codes first make sure not something easy
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs /
    233 bhp - 309 ft lb - 419 nm (NEEDS A NEW MAP)
    Sep 2013
    38
    I don't have vagcom unfortunately
    Any recommendations on a mapper who can map this out? Thanks guys
    LEE69's Avatar
    07 170 DSG
    Jul 2013
    898
    Quote Originally Posted by RyanB88 View Post
    Depends where you are?
    Sep 2013
    38
    Sorry should have said - I'm based in the Midlands
    LEE69's Avatar
    07 170 DSG
    Jul 2013
    898
    R-Tech in Leicester then
    Sep 2013
    38
    Car is now booked in for a full remap and warm start fix at R Tech, can't wait!
    Thanks to everyone who replied
    LEE69's Avatar
    07 170 DSG
    Jul 2013
    898
    Niki will look after you.
  1. SEAT Altea Hot Starting Issues
    By filipharvey in forum Volkswagen and other VAG
    Last Post: 23rd May 2012, 21:53
  2. starting issue when hot
    By 4rings in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th October 2011, 09:28
  3. Hot starting issue
    By vw754 in forum Volkswagen and other VAG
    Last Post: 15th October 2011, 20:54
  4. Cold start issues? Maybe it;s your O2 sensor.
    By eddyg in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st March 2006, 02:03
  5. 1.8 SE intermittent starting issue
    By easytease in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd February 2006, 09:42
