EM TuningJMB Retrofits
    Feb 2013
    Grimsby
    1,084
    Help needed urgently. need a new bolt from fuel pump.
    So replacing my cam follower which i posted about earlier last week, i finally did it! however after taking out the bolt from the fuel pump i noticed there wasn't much thread left, (the guy before me clearly screwed this up).
    BASICALLY screwing it back in, half way thru guess what, the thread went, not sure if it was in or not, i put the key in ignition and had a friend watch, after the turn fuel sprayed EVERYWHERE.
    I need to order a new bolt, but its a weird one with a hole in the middle of the bit that goes inside.
    Can someone link me a diagram, or blueprint thing of the fuel pump so i can find the number? and possibly say where i could buy it from?
    car is an 05 A3 2.0TFSI
    this is a photo showing the pump and the direction of the bolt.
    Uploaded with ImageShack.us
    Thankyou, i hope someone can help!
    JJ.
    27,028
    Quote Originally Posted by JJ.Foulds View Post
    Perfectly normal for a banjo fitting, otherwise the liquid wouldn't be able to go anywhere
    Feb 2013
    Grimsby
    1,084
    Thanks for the help! :P
    JJ
    Feb 2013
    Grimsby
    1,084
    il give audi a ring lol
    Feb 2013
    Grimsby
    1,084
    Local audi dealer can get one for friday for £21!!! sounds a right rip for a bolt! christ.
    I have till half 5 to ring and confirm it.
    Feb 2013
    Grimsby
    1,084
    im sorted now, i just ordered the one from audi just to get it sorted. next job is trying to get the old one out when theres no thread!
    thanks anyway!
  1. bought new cam follower, fuel pump looks different to one in video
    By JJ.Foulds in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd August 2013, 09:35
  2. A3 2.0tdi - leak from fuel pump & diesel in engine bay
    By M005 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th October 2012, 10:45
  3. New member from Argentina needs help!
    By santi wrx in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd March 2010, 02:34
  4. had to have new ECU and fuel pump!!
    By Icarter in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 23rd September 2009, 12:45
  5. Help urgently needed!!! New key needed
    By nicklght in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th November 2007, 01:16
