JMB RetrofitsAH Fabrications
Results 1 to 15 of 15
    Sep 2013
    London
    Emission Control Light and Limp Mode
    Hi all,
    I am totally new to this forum but have been reading it for a while for other issues which have helped massively.
    I appear to have a problem with the Emission Control System and the car going into Limp Mode. Last weekend we were heading to Silverstone and after reaching about 80mph the car went into limp mode and the ECS light went on... When restarting it everything was okay but the ECS light stayed on. The car is a A3, 2.0 TDI 05 Reg Automatic.
    We bought the car mid July and all seemed okay - took it for a health check and they reported back with a Error Code of P0234 for air pressure control limit and marked as sporadic. They also said the turbo was a little noisy but nothing to really be worried about. The garage I went to seemed to be all clued up and said they were audi specialists. At this stage no warning lights have been coming on - the ECS light would flash for a 2 seconds when starting the car but that is about it. They said it wasn't a massive thing and could be looked into more when we got a few bit replaced (back wiper motor and front water jet nozzle)
    Now - I am not too sure if this will have caused the issue but before we left for Silverstone the OH had put in 3 diesel fuel additives. He put in (all Forte brands) Advanced Formula Car Diesel Fuel Treatment, DPF Cleaner and Regenerator and Forte Diesel Turbo Cleaner. After this happened I spent a bit more time reading up and I don't think my car has a DPF filter on it - will this have caused the issue?
    The car seems to be running okay but I have noticed that the diesel is not lasting as long as it normally would. It hasn't gone into limp mode since this happened but I generally do 20 miles a day driving to work and back.
    Any advice/help would be appreciated!
    Thanks,
    Fuzze
    Brodster's Avatar
    Shark Performance In Scotland
    Mar 2011
    Scottish Borders
    3,390
    Follow Brodster On Twitter Add Brodster on Facebook
    This could be a multitude of things. I was going to suggest DPF but if you know you havent got it then that eliminates the worst case scenario. It really needs to be scanned with VCDS to see what error codes you have and then take it from there. Could be EGR, glow plugs, injectors etc etc. Have a look on the VCDS section and see who is nearest to you with VCDS and send them a PM asking for assistance. Someone will help nearby.
    Angelwax/BBS/BCS/Bilstein/Cobra/CTS Turbo/DTUK/H&R/K-Sport/KW/Loba/Milltek/Shark Performance/Oz Racing/TPI/VCDS/V-Maxx/Vossen/Wagner
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,324
    ​Hi, welcome to audi-sport.net. Have you had the car scanned with vcds to see if there are any underlying problems? x
    Jun 2011
    watford
    25
    Quote Originally Posted by fuzzelogik View Post
    Hi all,
    Thanks,
    Fuzze
    16618/P0234/000564 - Boost Pressure Regulation: Limit Exceeded (Overboost Condition) Possible Symptoms
    • Malfunction Indicator Light (MIL) ON
    • Boost Pressure too high
    • Reduced Power Output
    Possible Causes
    • Hoses incorrectly connected, disconnected, blocked or leaking
    • Boost Pressure Control Valve (N75) faulty
    • Boost Pressure Sensor (G31) faulty
    • Turbo Charger stuck/faulty
    Possible Solutions
    • Check Charge Pressure Control System
      • Perform Output Test (to check the Turbo Charger)
      • Perform Basic Setting (to check the Charge Pressure Control)
      • Perform Pressure Test to locate Leaks
    • Check/Replace Boost Pressure Control Valve (N75)
    • Check/Replace Boost Pressure Sensor (G31)
    • Check/Replace Turbo Charger
    27,013
    Welcome to the site.
    No dpf on your car & it is a bkd engine, more than likely its either egr, imf or turbo, as above scan with vcds, I hazard a guess it will say overboost condition & if so its pointing towards turbo.
    Sep 2013
    London
    Thanks for all the replies. Really hoping it isn't the turbo!
    Haven't had it checked over with VCDS but will have a look and see if there is anybody nearby.
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,324
    Where in london are you?
    Sep 2013
    London
    I'm in Wimbledon Sandra.
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,324
    Have a look at the link below. Click on blue balloons in your area, members details open up at the top, just send them a pm and ask them to scan your car. x
    https://maps.google.co.uk/maps/ms?ms...5&source=embed
    Sep 2013
    London
    Thanks Sandra!
    Had a brief look and all closet haven't been active for a while but sure I'll find someone.
    Sep 2013
    London
    Hi all,
    amit91987 came to my rescue and just had the car scanned.
    There was one fault which came up:
    1 Fault Found:
    16618 - Boost Pressure Regulation
    P0234 - 000 - Limit Exceeded (Overboost Condition) - Intermittent
    Freeze Frame:
    RPM: 2793 /min
    Torque: 274.0 Nm
    Speed: 117.0 km/h
    Load: 70.6 %
    Voltage: 14.14 V
    Bin. Bits: 11000000
    Absolute Pres.: 2111.4 mbar
    Absolute Pres.: 2590.8 mbar
    I've attached the report as well.
    Thanks,
    Lauren
    Attached Files Attached Files
    27,013
    Hey Lauren, that looks like a turbo fault & trust me it can blow anytime if it is caked up inside, so best routes are, remove clean & refit, but if when removed its got play in the shaft then its replace time, so either buy another of the same or upgrade to hybrid & map it for the turbo.
    I have a brand new turbo boxed if you do go down that route
    Sep 2013
    London
    Hiya,
    Was hoping it wasn't going to be the turbo but hey ho!
    Wouldn't be able to do this myself - any ideas what a good/reasonable price would be for somebody to remove, clean and refit it? Just out of interest, what would I be looking at for the new one you have?
    Thanks!
    amit91987's Avatar
    Nov 2010
    South West London
    101
    Visit amit91987's Instagram Channel
    Audi VW Volkswagen Skoda Seat Independent Specialist London
    I recommend these guys. They know their stuff and not that far.
    19" speedlines, S3 rear, LED tail lights, Votex Spoiler, Bi- Xenons, Auto lights, Cree Led fog lights, Eibach Sportlines, Tints, Pioneer HU, Reverse Camera, Carbon fibre trims, LED interior lights
    Sep 2013
    London
    Brilliant- thanks for the recommendation :-)
    Quote Originally Posted by amit91987 View Post
  1. Uh..oh... Flashing glow plug light and limp mode :(
    By dubdemand in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 2 Days Ago, 17:03
  2. Emissions control light following DPF and limp mode
    By Abbie8101 in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 23rd September 2013, 14:52
  3. Flashing Coil / Glow Plug Light and Limp Mode
    By 5aq1b in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 9th June 2013, 21:20
  4. Latest woe. EPC and ESP lights and limp mode
    By duffy78 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th February 2013, 07:46
  5. Engine Mgt, ESP and Emissions control light on - help!!!
    By razza1 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 3rd August 2010, 11:55
Tags for this Thread
