AH FabricationsChris Nott
Results 1 to 9 of 9
    imported_hburnett
    Heated wing mirrors
    Just wondering, but isn't the Sport supposed to come with heated wing mirrors? Because I've noticed that mine don't really heat up! bum pooh!
    h
    Sep 2005
    UK
    320
    Re: Heated wing mirrors
    [ QUOTE ]
    h
    [/ QUOTE ]
    "Wing mirrors"
    What a lovely quaint expression! They don't fit them anymore....
    If it is the door mirrors you have then they work when the heated rear window is on.
    imported_hburnett
    Well bad me for being politically incorrect.... [img]/ubbthreads/images/graemlins/wink.gif[/img]
    I thought that the 'door' mirrors (hehehe) are heated with the rear window on, but I haven't seen any thing to say otherwise... Just becomes a messy mirror!
    h
    OutLore's Avatar
    VOIP Dude
    Oct 2003
    Essex, UK
    1,183
    Didn't we have this a while back?
    UK Spec cars only heat the mirrors when the mirror control switch is in the "Central" position - IE not able to adjust either mirror. If it is to the left or the right then they won't heat up. The rear demister does not need to be on for this to work.
    Outside the UK, they work with the rear demister.....
    Sep 2005
    UK
    320
    Heated door mirrors - aside from the light dew we experience in the autumn the rest of the year a heated mirror simply bakes the crap onto the glass - net result is that you still can't see!
    So get hand out and try and clear dried on crap and transition that into a smeary mess....................... [img]/ubbthreads/images/graemlins/confused.gif[/img]
    imported_hburnett
    ahhh that'll be the problem! it's to the left... Dope! Cheers for that OutLore!
    Dec 2004
    Chester
    247
    [ QUOTE ]
    [/ QUOTE ]
    Mine work regardless of where the mirror adjustment is, I always leave the mirror switch pointing to the passenger side so I can adjust it down when parking, heaters work fine, maybe it's a Sportback trait?
    OutLore's Avatar
    VOIP Dude
    Oct 2003
    Essex, UK
    1,183
    [ QUOTE ]
    [/ QUOTE ]
    DOH! I hadn't considered the Sportback Curse!!! [img]/ubbthreads/images/graemlins/idea.gif[/img]
    I wonder if the facelift A3 3Dr is the same then [img]/ubbthreads/images/graemlins/noidea.gif[/img]
    Dec 2004
    Luxembourg
    161
    [ QUOTE ]
    [/ QUOTE ]
    Nope. Central position thingamajig on my car too.
