Volks AutosEM Tuning
Results 1 to 27 of 27
Like Tree2Likes
  • 2 Post By SmithyAG
Thread: WARM START FIX
    tdi-man's Avatar
    Jul 2009
    1,611
    WARM START FIX
    why is it some cars need a warm start map to make car start first turn of the key when warm.
    i have this in mine but wonder since ive had a new head and bottom end rebuilt if i need it .
    going for another map soon
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs /
    233 bhp - 309 ft lb - 419 nm (NEEDS A NEW MAP)
    Jul 2013
    SY
    71
    I have this problem takes 3/4 turns when engine is hot. Anyone know the cheapest and quickest way to resolve it?
    LEE69's Avatar
    07 170 DSG
    Jul 2013
    896
    Coolant temperature sensor gives this fault.
    Growing old is mandatory, growing up is optional
    Aug 2013
    27
    I had it mapped out. Wouldn't tell me what the actual cause is but it's been spot on since.
    Jul 2013
    SY
    71
    Quote Originally Posted by kyleseo View Post
    How much was it and where can you get it done from. If I get a remap done will that solve the issue?
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    New battery fixed it in my case.
    VCDS USER
    tdi-man's Avatar
    Jul 2009
    1,611
    I changed every Think didn't fix it so was mapped out.
    J8TT X's Avatar
    Jan 2011
    Leicester
    337
    I checked/changed loads of things, nothing worked so I got it mapped out when I got my car remapped from R-tech.
    2005 Audi A3 2.0 TDI DSG S-line (8p1)
    Mods: 18" Gloss Black RS4's - 8p2 S-line Front Bumper - Black Grill - A5 LED Number Plate lights - LED Sidelights - Euro Style Plates - EGR Delete - RTech Custom Remap - Hot Start Issue Fix
    Pipeline: Lowering, Wheel Refurb, Coming Home Lights
    2007 VW Golf 2.0 GT TDI 140 (Wife's)
    Mods: 18" Charlestons
    Aug 2013
    27
    Quote Originally Posted by emznjav:1958778
    Was done by a Quantum tuning rep locally. Got it generically mapped at the same time and had the EGR light disabled. Think it cost about 180 for the lot. I had to request the hot start fix and EGR.
    AudiMafia's Avatar
    Apr 2009
    London
    403
    Quote Originally Posted by LEE69 View Post
    Ive tried this when I have removed the coolant temps sensor off and it still does it? is it the crank shaft sensor? or the clutch?
    A3 8P 2.0TDI 140 Sport | Blue | Full Leather Heated Seat | BOSE | 6 Disc Changer | None Smoking Pack | | Nav | Xenons |
    Mods | 18" Rotiform Staggered | Tinted Windows | S3 Spoiler | 2009 S-Line t Rear | Front Chin Spoiler | Wind Deflectors | Re-Map |
    | MY11 Lights | S3 Side Skirts | Private Number Plate | Milltek Exhaust | S Line Gear knob
    AudiMafia's Avatar
    Apr 2009
    London
    403
    Had quantum map on mine, hows it been on ur car? i never thought to ask them about the hot start fix :/
    Aug 2013
    27
    Apart from the turbo recently blowing lol? I'm pretty that is a turbo issue and the map didn't cause it though. The extra strain might not have helped but it was going to go eventually.
    Happy with the map. Power wise it was conservative but MPG increased by about 10% on a good run. The hot start fix worked and has been fine ever since. I doubt they would charge much just to add the hot start to your file.
    Feb 2014
    I need help! Hot start problem!
    I have a 1.9tdi PD105 which used to take ages turning over when warm. On cold start its fine, however it used to turn over for ages till it actually fired up. I had it remapped to 135bhp by Midland Remaps and he cured the problem. He said it is a common fault being a slow crank speed, so he set the ECU to send the fuel in sooner causing it to fire up first time every time.
    HOWEVER! Around 10,000 miles since the map, on hot start there's been a couple times where it just about turns over and just gives up and simply doesn't start, literally like as if the battery is dead, the battery test shown that its still strong. So I have no idea what it is? Starter motor maybe?
    Its like the car picks and chooses when it wants to fire up on hot start. Sometimes it turns over really slow but still fires up, sometimes there's no issues, and twice now it just hasn't started until the engine cooled down.
    Thanks, Gavin
    SmithyAG's Avatar
    Dec 2013
    Manchester
    355
    Follow SmithyAG On Twitter
    Your tuner is correct. The hot start problem is caused by a lazy starter motor. The ECU doesn't inject fuel on a warm engine until its over about 280rpm. On a cold engine it injects fuel straight away to help it start.
    It sounds like your mapper has lowered that 280rpm figure, which helps it start when hot. The problem is now your starter is so lazy that it struggles to get to the revised figure.
    People often think a coolant temp sensor is at fault, because when you unplug it the car fires first time. This is because the ECU defaults to a cold start when it has no reading from the sensor.
    SAiLO and kanecullen89 like this.
    Feb 2014
    Quote Originally Posted by SmithyAG View Post
    Excellent advice. Makes a load of sense. I'll be getting the starter motor changed today and I'll let you know how i get on. Many thanks.
    SmithyAG's Avatar
    Dec 2013
    Manchester
    355
    Please do, would be good to know its worked!
    Feb 2012
    Chelmsford Essex
    22
    It`s nothing to do with the map , my brother was checking for error codes on mine and on doing this he noticed the **** slow warm start issue . He promptly did some googling as he remembered something about it , then he advanced something witch actually worked . So i don`t know how but it can be done on VCDS and ever since has started really well when warm
    SmithyAG's Avatar
    Dec 2013
    Manchester
    355
    So he may have advanced the fuel injection point on a hot start?
    Which is exactly what we have being saying. Maybe we were a bit lazy and called a software change a "map". However, the principle remains the same.
    May 2009
    south yorkshire
    628
    hot start fix is definately done in the map ,never heard of any fix via vcds . fuel isnt injected if the rpm is too low .
    SmithyAG's Avatar
    Dec 2013
    Manchester
    355
    That's what I thought. It was the previous poster who suggested it was done via VCDS.
    I've only ever seen it done through a map. Although it can be done without a performance gain, so not necessarily part of what most think of as a "remap".
    May 2009
    south yorkshire
    628
    yeah was re-enforcing your post
    Feb 2012
    Chelmsford Essex
    22
    Well my car starts better than it ever has and it has not been near a mapper . I will ask my brother what he did later in the week
    SmithyAG's Avatar
    Dec 2013
    Manchester
    355
    Let us know alastair, would be interesting to see what he changed to see an improvement.
    May 2009
    south yorkshire
    628
    maybe adjusted cam timing . but wouldnt be with just vcds, spanners required as well
    Feb 2012
    Chelmsford Essex
    22
    No, i buggered around for hours trying to get the cam timing just right . It was no better so i gave up , he fixed it in no more than 5 min , i`ll see him thursday so i will ask
    May 2009
    south yorkshire
    628
    out of curiosity what year / engine do you have alastair0903
  28. #27
    tdi-man's Avatar
    Jul 2009
    1,611
  1. 1.8t avant warm start problems help!
    By Mark L in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th September 2013, 14:24
  2. Warm starting/IMF/Aircon probs - Anyone help?
    By tates1979 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th September 2009, 17:30
  3. warm starting problem
    By emjim09 in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th June 2009, 21:38
  4. 1998 S4 warm starting problem? HELP!
    By myfirsts4 in forum General Technical / How To
    Last Post: 15th July 2007, 11:19
  5. 1.9 tdi (1997) warm start problem
    By markf497 in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th September 2006, 17:20
