Monster MotorsportEM Tuning
Results 1 to 12 of 12
    Feb 2011
    Aberdeen
    96
    Fitting Adaptive Bi-xenons (Non DRL) instead of Halogens
    Picked up a set of Adaptive Bi-Xenons (Non DRL) and in the process of fitting them to my 2005 A3 Sportback.
    When I bought them I naively thought they were plug and play.
    I am at the point where I need the adapters but want to check if I am getting the correct thing.
    Audi A3 8P + TT 8J Xenon headlights adapter cable set, suitable for Bi Xenon | eBay
    Also reading a few threads it mentions wiring back to central electronics module, but to where exactly?
    Also what needs to be done on VCDS.
    Finally, to be right I should fit headlight washers, how much work is this and what would I need.
    Thanks in advance.
    27,029
    Adaptives will not work for cornering or levelling without installing the levelling system, the lighting side if wired/coded correctly will work.
    Feb 2011
    Aberdeen
    96
    Ok, lets ignore the adaptive/ levelling for now, might go back to it later
    Would like to concentrate on getting the wiring and coding done correctly so they actually work.
    27,029
    Those adapters look suitable yes, however make sure the ce module (vcds module 09) is the correct version to be able to code the correct headlight fitted or you may have issues with flickering or lights not working properly with dis warnings.
    Feb 2011
    Aberdeen
    96
    Ok, thanks again.
    Sep 2012
    Keighley
    53
    Surely if the headlights are not capable of leveling nor have headlight washers it will fail an mot? I have a set of single xenons and was put off installing them by the fact of having to install all of the leveling gear not to mention a new front bumper to accomodate headlight washers. The job costs thousands done properly.
    Just a thought
    27,029
    Comes down to mot testers, according to mot rules, yes they should have levelling systems & washers fitted.
    Sep 2012
    Keighley
    53
    I happen to have noticed that they also use a different type of leveling motor to the halogen ones so you wouldnt be able to level them using the leveling buttons inside the car? only manually using a screwdriver on the back of the headlight?
    27,029
    Indeed.
    Feb 2011
    Aberdeen
    96
    I am aware of the mot requirements, but first things first, need to get the lights working properly first, then look at the washers and levelling.
    Feb 2011
    Aberdeen
    96
    Now got the lights fitted and working, also fitted the headlight washers and wired them in, can anyone tell me what coding I will need to do so the washers work correctly. Thanks in advance.
    Feb 2011
    Aberdeen
    96
    Quote Originally Posted by Coling View Post
    Thanks for all the replies managed to figure it all out and everything is now fitted and working.
  1. Replies: 0
    Last Post: 12th May 2013, 15:35
  2. Genuine RS4 S4 A4 B8 Bi-xenon LED DRL Headlight Adaptive 2012 onwards
    By Lewbo in forum For Sale/Wanted - Audi Parts
    Last Post: 12th May 2013, 15:28
  3. Self Levelling Xenon with DRL's Fault
    By Lion Man in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th September 2010, 09:25
  4. Setting adaptive bi-xenons for use in Europe
    By warren_S5 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th March 2010, 13:31
  5. Do I have DRL's? 2004 S-Line with OEM Xenons (non-LED)
    By Joe90k in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th February 2010, 17:38
