Monster MotorsportChris Nott
    Oct 2008
    coventry
    32
    coolant warning help
    Hi all I noticed when I came back from holiday my coolant warning is displaying, I haven't looked yet to see if it is low level, if it is low what mixture should I use to top up?
    26,716
    G13 from audi, 50/50 mix.
    Oct 2008
    coventry
    32
    But in the first instance can I just top up with water until warning goes off?
    26,716
    Yes, but did you check the level & it is low right, if not then scratch the 2 prongs inside the reservoir, this fixes some coolant warnings on cars that have good levels.
    Oct 2008
    coventry
    32
    OK I will try that thnx
    LEE69's Avatar
    07 170 DSG
    Jul 2013
    789
    Still using the same bottles as the 2001 Leon used, scraping the prongs worked on that too.
    Growing old is mandatory, growing up is optional
  1. Please Help! Radiator leaking! Red Coolant warning light coming on.
    By Massey127 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th June 2013, 18:33
  2. help needed (COOLANT WARNING)
    By gixxer600k4 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th January 2013, 13:02
  3. Coolant Warning HELP
    By Grazam in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th January 2012, 14:00
  4. Help coolant warning and high temp
    By Steve_N in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th March 2010, 19:34
  5. Help - coolant warning light on S3
    By bantam1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th January 2007, 16:17
