Chris NottBadger5
Results 1 to 7 of 7
    41
    MAF Problems - 2.0TDI. Help!
    Hey guys.
    I need some help. I have a 2004 BKD A3. It's making no boost, and is not smoking at all. I checked it and its bringing up a MAF signal too low code constantly. I fitted a new MAF and it's still the same, clear the code and it comes back straight away!
    Any ideas? I'm tearing my hair out with it! Looked on the net loads and can't find anything either.
    41
    I've checked the wiring and it looks good too. The plug looks to be alright aswell but might need fuehrer checking on that? The TIP is on the turbo fine aswell. Its draining me!
    Lewis583's Avatar
    Mar 2010
    870
    Air filter clean?renewed recently?
    All boost pipes connected properly?
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    41
    The turbo was really noisy so I've ended up taking it off for a rebuild, was all moving freely though. Will get it back on and go from there..
    41
    Refurbished turbo fitted, new oil feed and oil and filter. Took the EGR off too. Still got the MAF fault?
    Going to fully strip the plug on the MAF down later and see if I can see anything. Does anyone know where the hoses go off the black vacuum control box? They're labelled up 1-6..
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    745
    Quote Originally Posted by Shorty_rs View Post
    Did you buy A genuine MAF? There's a lot of replacement parts available out there & 90% of them are cack.
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted... Still....
    41
    Yeah genuine, I wouldn't bother with a patter part on something like a MAF. Also tried a friends MAF as I thought I might of been sent a broken new one, but still the same.
    Someone has told me to check the wiring under the battery tray?
  1. Help with MAF problem please??
    By sherry in forum A6/S6/Allroad forum (C6 Chassis)
    Last Post: 10th September 2012, 07:16
  2. possible maf sensor fault........ pls help
    By lazzaman in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th January 2006, 09:24
  3. Limp Mode/MAF Problem????
    By GarryX in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th August 2005, 11:10
  4. hot engine problem , can anyone help please ????
    By Jonny_doe in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th January 2005, 20:33
  5. Remote central locking problem!someone please help
    By Add7 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th July 2004, 13:43
