Volks AutosEM Tuning
    Jul 2013
    302
    prop shaft help s3
    hi guys just a quick question what bolt hold on the prop shaft from the transfer box ?
    i am assuming they are a triple square bolt (16 sides) someone has chewed the edges a bit when they are removed it in the past so just wanted to confirm what they are so i can try hitting the correct socket onto them !
    Apr 2013
    Aberdeenshire
    580
    Quote Originally Posted by s3_sid View Post
    Do you have photos ?
    Jul 2013
    302
    not relay its a funny place to get a phone in to get a focused picture !! and im doing it on my back ! its not a normal 12 sided socket as iv tired and they aint fitting on it so thats the only thing i can figure they would be ! i may end up using easy outs to get them out yet ! but i cannt find any information on the net ! i could do with someone with a copy of the latest etka to see what bolts the are !
    AudiMafia's Avatar
    Apr 2009
    London
    403
    try ETKA here http://vin-online.ru/ make sure you have downloaded google chrome so it translate from Russian to English.
    I use t all the time when i need to see things
    A3 8P 2.0TDI 140 Sport | Blue | Full Leather Heated Seat | BOSE | 6 Disc Changer | None Smoking Pack | | Nav | Xenons |
    Mods | 18" Rotiform Staggered | Tinted Windows | S3 Spoiler | 2009 S-Line t Rear | Front Chin Spoiler | Wind Deflectors | Re-Map |
    | MY11 Lights | S3 Side Skirts | Private Number Plate | Milltek Exhaust | S Line Gear knob
    Jul 2013
    302
    Cheers mate well I have a full copy if elsawin but it dosent tell you what bolt it is ! It just say m10x30 bolt ill have to have another look at it !
    Bullys3's Avatar
    Mar 2013
    Scarborough
    185
    M10x30 is a m10 bolt 30mm long that's all !
  1. Help ! How do I move the prop shaft out of the way to fit Dp
    By dre_S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th November 2012, 13:46
  2. HELP PROP SHAFT REAR SEAL LEAK !!!
    By audi avant in forum General Technical / How To
    Last Post: 3rd August 2010, 21:39
  3. Puzzled - Possible Prop Shaft Query
    By brettp in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th March 2010, 20:41
  4. Help!! Anyone know where I could get a Prop Shaft?
    Last Post: 2nd March 2010, 14:44
  5. Wanted...Avant 2.5 Quattro Subframe and Prop shaft
    By ims1 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th November 2004, 00:50
