finally had the darkside developments budget kit gtb1756v fitted choose this kit instead of going for the gtb2260 as I wanted to keep the spool as low as possible.
well all I can say is wow such a different car and just feels so fast now even in 6th at 30mph(not recommended) will still pull off the turbo has transformed the car along with great mapping.
I have a bkd Quattro and it always felt heavy and felt slow low down but now feels so light and quick. around town the spool is great you never seem to get caught out in the wrong gear as you can still pull away fine if you do put it in the wrong one.
also had there own cone filter fitted which looks good and sounds great not over the top just a subtle whoosh noise.
can not recommend ryan and scott at darkside enough while fitting my kit they had trouble with the rolling road as its a Quattro and didn't seem to like just front wheels running and began grabbing also abs esp went mad turns out after two days finding out what was causing it the abs ring had broke don't know how or why but they replaced it and car was back running great it ended up making 229.5hp and 340ish lbs torque when it was having problems so could be a little more now
before this kit I had a turbo dynamics hybrid stage 2 fitted I cannot compare the two its like night and day if you thinking hybrid for your diesel don't do it, go for this kit you will not be disappointed
