geordiegooner
hi
im going to have a look at a audi a3 2.0 tdi sport 53 plate which has been described by the seller with the following problems:
everytime it gets to 60 mph it go,s into limp mode and you have to restart the car again to get it back to normal again and has been plugged into code reader and it said the mass air flow meter was at fault so she had new one fitted and still same problem.
its taxed and tested with 134k on the clock but with full history and only going to be used as my winter hank.
So what should I be looking at when I go to view and what could be causing the problem with the car going into limp mode.its a bit strange that the sellers also selling a vw Sharon with the same problem of it going into limp mode at 60mph is it a common fault.
thanks for any help
thanks for any help
