AH FabricationsVolks Autos
    h90
    h90's Avatar
    Aug 2013
    Question Aux-in issue (Factory fitted)
    Hi there, I've got a 2008 A3 with a factory fitted aux-in port in the centre console. I can't get the radio (Audi symphony II+ / 6 CD changer) to switch to the aux input / detect theres something playing. Tried using both my Ipod and phone to play music via a tested 3.5mm jack cable.
    I'm following the manual's instructions to turn on radio, switch to tuner, connect device via cable, then repeatedly press the 'CD' button to switch to aux.
    Any ideas how to get it working?
    Tried
    • Turning up the volume on the ipod/phone to max.
    • All different combinations of turning on the system and playing music and pressing the cd button.
    Cheers, h90
    -- A3 2008 1.8TFSI --
    27,129
    Make sure the connector is fully pushed in as some don't realise it needs an extra shunt.
    h90
    h90's Avatar
    Aug 2013
    Yep, its totally flush with the socket.
    27,129
    Tried another cable?
    A3Kent's Avatar
    Different Gear
    May 2012
    1,066
    Just seen this guys post - AUX Input for Audi Concert Radio
    Not sure if it's relevant to you or not but it might help
    09 Audi A3 2.0 TDI 170 S-Line SB 8P3
    - Full Leather - LED DRL's - BOSE - Cruise Control - RNS-E Mk2 - AMI - Bluetooth - Folding Mirrors -
    VCDS owner - A3 Grille Install Guide
    h90
    h90's Avatar
    Aug 2013
    Yeah I'll be heading down the local dealership, cheers guys.
  1. Factory fit sub woofer upgrade
    By in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th March 2011, 10:45
  2. Factory fit Car Phone Preparation
    By Aldo in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th August 2006, 22:29
  3. Vag factory fit alarm
    By maxlbrown in forum Classic Audi Forum
    Last Post: 10th May 2006, 16:02
  4. Factory fitted tyres
    By QuantumJohn in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th January 2005, 21:31
  5. Factory Fitted Bose
    By Anito in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th December 2003, 01:28
