Chris NottEM Tuning
Results 1 to 13 of 13
    Dec 2010
    Littleborough
    105
    00470 Fault Code - Help required please
    Hi All,
    ive just fitted a genuine towbar loom to my A3 this afternoon, since connecting it and enabling in the Can Gateway #69 Trailer, I now have the below fault showing....
    i haven't changed any other parameters other than enabling #69 Trailer
    any ideas as to what I've done wrong?
    below info fron Ross Tech website
    00470 - Combination comfort Databus in Single Wire: Open Circuit
    Possible Symptoms
    Data Bus Comfort working in Single-Wire Mode
    Possible Causes
    Wiring/Connectors from/to Control Modules
    Control Module in CAN Data Bus Comfort faulty
    Possible Solutions
    Check Measuring Value Blocks (MVB)
    Check Wiring/Connectors from/to Control Modules
    27,129
    1 of the canbus wires isn't connected properly or at all, hence single wire error.
    Dec 2010
    Littleborough
    105
    Ok thanks, I take it they are the two orange wires (orange/green and orange/brown)?
    27,129
    Indeed.
    May 2012
    RETFORD, NOTTS
    1,753
    u can check ecu measuring blocks around 125 and maybe up and down a few to see if anything shows up, no number is not installed, 1 is working 0 is failed connection iirc.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Dec 2010
    Littleborough
    105
    #Confused ?
    27,129
    Just check your wiring for now.
    Dec 2010
    Littleborough
    105
    Ok, checked wiring tonight and all appears to be in order, I connected the two can bus wires to the back of block "G" using Scotch locks, its wired exactly the same as it was on my 2007 A3?
    I have attached the below screen shots to try and give you some info, I'm not an expert with VCDS and don't really know how to use it for things like this.
    27,129
    Scotch locks are shxt, do it properly & solder
    Dec 2010
    Littleborough
    105
    You still convinced it's these two wires into the back of block "G"?
    27,129
    Block G where, ce module??
    Dec 2010
    Littleborough
    105
    Yes
    27,129
    As I said remove scotch locks & test wound around the wires directly, as scotch locks are crap & don't connect very well at times, I never use them.
  1. Got few fault codes, help needed please as new to VCDS
    By JMB-S3 in forum VCDS (formerly VAG-COM) forum
    Last Post: 13th May 2014, 15:43
  2. Fault Codes - Help Required !
    By mikes3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th April 2010, 20:52
  3. 2.8 Fault code help please
    By stapo69 in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th January 2009, 20:54
  4. FAULT CODE HELP PLEASE
    By 1wheelonly in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th November 2008, 07:14
  5. FAULT CODE HELP PLEASE
    By 1wheelonly in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th November 2008, 18:31
