AH FabricationsSky Insurance
Thread: Engine misfire
    Aug 2013
    Cornwall
    Engine misfire
    Hi guys I got a 2004 2.0 fsi a3 and been having recent engine issues like my engine management light coming on, one of the parents friends has a snapon ethos machine and we read the fault codes and it is bringing up misfires on 2 and 4 cylinder does any one have a clue what could cause this ? Thank as I don't want to throw money at pointless things
    Jun 2011
    Greenock
    214
    I would try your coil packs mate, that was the problem with mine when I had a misfire. the engine management light also started flashing when under strain too.
    Apr 2013
    Aberdeenshire
    592
    Quote Originally Posted by stuartm View Post
    As above mark and swap your packs around to see if the fault moves with the packs also your packs may be subject to a recall so its worth checking with audi before spending £
    Aug 2013
    Cornwall
    Cheers guys will swap them round tomorrow and get it looked at on the machine then change if they are at fault.
    Mar 2013
    23
    As above, you'll probably notice the engine ''shaking'' on idle as well do you?
    I also have a 2004 2.0 FSI and my coil packs had the recall out standing - cylinder 2 and 4 failed on me also so speak to audi and they'll check to see if the recall had been carried out, mine was repaired free of charge.
    Aug 2013
    Cornwall
    Yep I get that on idle too, will go audi on Tuesday and have a word thanks for the help
  1. Help, A3 1.8t engine misfiring
    By dougal in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th April 2013, 19:33
  2. Engine Misfire
    By eggman in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st July 2012, 00:59
  3. 3.2 Engine Misfire
    By stevenbeedie in forum A6/S6/Allroad forum (C6 Chassis)
    Last Post: 7th March 2012, 14:07
  4. Engine Misfire - Can't access spark plugs
    By silverswish in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th March 2011, 14:19
  5. Help!! - In dire need of advice... engine misfire
    By Raspeir in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd June 2007, 14:21
