Badger5Volks Autos
Results 1 to 11 of 11
    Biggles44's Avatar
    Aug 2013
    60
    Starting problems
    Hi all, I recently bought a A3 2.0TDI 170bhp, s-line 2007 with 100,000 miles, privately.
    Had the car for two weeks now and love it to bits. The wife got in it earlier, put key in the ignition and went to turn it over and it wouldn't start. I went to try it and turned it over, first of al it seemed liked the battery was vey low, then it turned over fine but took a while to start. Turned it of and turned it over again, again it took a while to start but did. Seems strange as when its running its perfect.
    Been looking at forums and a lot are saying injector issues and about a recall. Looked in the service manual and under workshop remarks it says 23k1, is that a recall code, does it mean its been done or to be done ? Can not find anything to say its been done, can't ring audi to find out until Tuesday.
    any help or comments will be really appreciated
    Tim
    RobbieWebs's Avatar
    Apr 2013
    Scotland
    739
    Starting problems
    Injector Recall for PD170 - Might be already known to you lot.
    Already a thread on it m8 with that code.
    Post 48
    Google is ur friend
    Audi A4 BE 2.0 TDI 177 Quattro
    Biggles44's Avatar
    Aug 2013
    60
    Thanks mate, will have a read :-)
    Biggles44's Avatar
    Aug 2013
    60
    Does this pic from my service book mean the recall has been done or an advisory for it to be done ?
    Biggles44's Avatar
    Aug 2013
    60
    RobbieWebs's Avatar
    Apr 2013
    Scotland
    739
    Starting problems
    Well apart from it being upside down it looks like its been done lol.
    Best way to check is to phone Swindon audi and ask mate.
    Put ur mind at ease
    I'd get someone with vagcom to scan ur car to see if any faults have come up as well
    Biggles44's Avatar
    Aug 2013
    60
    So with the description I gave in top post, would people say its an injector issue or something else ?
    really starting to df me off now :-(
    Oct 2012
    139
    Quote Originally Posted by Biggles44 View Post
    Could be the battery. I had starting issues and a new Varta Silver battery solved it.
    Seems the factory fitted battery isn't great and doesn't seem to last that long compared to any other car I've ever owned.
    Aug 2007
    439
    Measure your battery voltage before starting and during starting. If you have a cigar lighter socket use this. If your battery is less than 12.4v before starting then it's not fully charged. If your voltage drops below 10.3 volts when starting your battery is struggling.
    I use one of these. They're very useful. Ring Battery Tester - Demon Tweeks
    A3 2.0TDI Sportback S Line 184 Quattro S-Tronic, Mar. 2014 Glacier white. Electric seats, sunroof, se suspension, heated folding mirrors, Reversing camera, Nappa leather, TPMS, Hold assist, Xenon plus adaptive lights with variable active range control, lane assist, Interior light pack, Technology pack, Comfort pack with ACC, park assist & parking system plus
    27,114
    07 car, possibly original battery, 6 years old is over the normal usage of them, as above get this tested 1st before condemning injectors as there are other things easier to check like fuel filter, maf etc.
    Biggles44's Avatar
    Aug 2013
    60
    Ok thank you ill try that. :-)
  1. HELP (STARTING PROBLEMS)!!!!
    By harps21k in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th June 2004, 20:13
  2. a4 starting problems
    By lazzaman in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th June 2004, 12:44
  3. 100 with starting problems
    By SaabManIan in forum Classic Audi Forum
    Last Post: 26th April 2004, 03:01
  4. 2.5TDi Starting Problems
    By aj_mackay1 in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd April 2004, 19:47
  5. 2.5TDi Starting Problems
    By aj_mackay1 in forum General Technical / How To
    Last Post: 22nd April 2004, 12:28
