    NME
    NME's Avatar
    Mar 2011
    Near the Muller Dairy!
    139
    Adjust DRL brightness on facelift cars
    Right,
    I've done my searching and I thought I would create this thread as I'm confused about what I read.
    I read a post which Paullie created asking how to make the DRL brightness its full setting (100%) when the sidelight switch is used, as it said that they are dimmer when the side light switch is selected.
    Paullie then said that the solution for Sportbacks is Module 09 / Byte 18 - change from 2B to 2C.
    I have done this, but can't see any difference - is this correct for only a certain year of car?
    I have a 2011 car, and my standard setting in Byte 18 is 2B.
    The reason I wanted this mod done, is that I have auto lights, and the headlights come on way to early (i.e. it is still very light and not dark enough for full beam with side lights).
    A few other people commented that the DRL's on auto lights - were brighter in the daytime when the full head light has not come on.
    I also tried changing the setting to 26 (as Paullie said this was what worked for her in her facelift 3 door), as her standard setting was 25.
    Can anyone confirm the correct way to increase the DRL when only the sidelight option is seletected on the Sportback model?
    NME
    NME's Avatar
    Mar 2011
    139
    bump.
    Sep 2012
    Prague, CZ
    88
    I tried doing the same thing a while back... when I tried doing it, it looked like you needed the know the security login for the controller which I was unable to find out from anywhere on the web.
    The other option is enabling DRLs @ 0 position on the light switch (which would be DRLs @ 100%), which according to many threads is possible but no one could tell me the correct coding.
    2009 A3 TDI 170 STronic SLine
    May 2012
    RETFORD, NOTTS
    1,712
    its obvious when in vcds where to adjust the % but i dont have a car in front of me to tell you sorry, just go through the long coding helper
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    DeckedS3's Avatar
    Apr 2008
    South East
    550
    I tried playing with this a while ago and I never figured it out!
    Meteor S3, APR Stage 3, APR HPFP, Milltek TBE, LOBA/Sach's Clutch, Bilstein PSS10's, H&R ARB, Gen4 Haldex PP, EVOM's DV & CAI, Forge TB with Pro-Alloy IC, BBS CK 19" My S3
  1. LED DRL brightness, can it be adjusted
    By Sem in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th March 2011, 12:09
  2. Facelift cars
    By 951 in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st February 2007, 17:33
  3. Facelift wing mirrors on pre-facelift car?
    By G Force in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th February 2007, 21:43
  4. Facelift front seats into a pre facelift car?
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th August 2006, 12:46
  5. Facelift head lamp guys on pre facelift cars.
    Last Post: 8th December 2005, 18:58
Tags for this Thread
