AH FabricationsChris Nott
Results 1 to 7 of 7
Thread: Rear wiper
    alexi77's Avatar
    Dec 2012
    Kent
    82
    Rear wiper
    Help, my wifes A3 tdi Sportback has a problem with the rear wiper. It has happened a couple of times now.
    The rear wiper stops in the middle of the screen and will not move. I turn off/on, the car and still nothing, is the motor going to pack up.
    Its a 2010 quattro and hardly used.
    Alex
    Aug 2013
    Durham
    12
    Mine was doing that, took it apart and the motor is corroded inside. The washer sprays through the centre of the motor mechanism and when the seals go it leaks inside and corrodes everything. Be careful and get it checked soon because mine had started to leak onto the boot release mechanism and it can corrode that too. A new motor is around £80 and should only take half an hour to fit.
    Apr 2013
    mansfield
    87
    The pipe that goes through the middle of the motor for the washer is broken so water leaks inside the motor and corrodes and shorts it out mine did the same. It's a common fault there is a guide on here to fix using a plastic spray bottle tube if you don't want to buy a new motor.
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    Mine did that when I tried to wipe the rear screen on a dry day. It's been working since rain lubricated the screen surface, although I got a feeling it will day soon. 04 plate.
    VCDS USER
    Jun 2011
    Greenock
    214
    My rear wiper did the same thing, so I managed to get it back to the original resting place and pulled the fuse out and I don't use it anymore.
    27,033
    Hey Alex, jets get blocked & any water stays within the unit & leaks as advised above, so either remove all, clean up any wiring & see if it works again or has to be replaced, ping me an email if you're not confident in sorting & I can get it sorted for you
    audicruiser's Avatar
    Audi Heaven
    Somerset
    1,861
    The wiper motors have been revised now so they are sealed better to stop the washer fluid entering the motor casing. A new motor is around £95.
    Scott
    Audi A3 Sportback 2.0T Quattro S-Line 2007 8P2
    Lava Grey, Exclusive Line Black/Silver Leather, Heated Seats, Bose, RNS-e, iPod, Auto Lights & Wipers, Interior Light Pack
  1. Rear Wiper Jet
    By Stepho in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd October 2004, 10:15
  2. rear wiper
    By imported_velcrobix in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd October 2004, 23:49
  3. rear wiper stuck
    By Haris in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th July 2004, 15:44
  4. Stuttering rear wiper
    By ben in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd December 2003, 22:15
  5. replacement rear wiper arms
    By Khufu in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th September 2003, 14:54
