JMB RetrofitsAH Fabrications
Results 1 to 13 of 13
    Aug 2013
    6
    New Timing Belt, now a "thump' on start up. Related? Flywheel?
    Hi All,
    just had the timing belt replaced on my 75k 2006 A3 2.0TDi. Got it back and immediately I noticed a bit of a delay on turning the key and then a thump on start up. When I turn the ignition off the engine does seem to turn over a moment longer than it should (less than a second but noticeable). The car runs just fine, no slipping of clutch or other engine issues.
    I was thinking maybe the new belt was out by a tooth (if that's still possible) but reading these posts could it be the flywheel? If so, why didn't I get this before the timing belt was done?
    and how much is it going to cost...?
    Many Thanks.
    27,099
    Who changed it?
    Aug 2013
    6
    Local Audi Dealer.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,510
    take it back to them asap
    Aug 2013
    6
    Thanks Bez and NHN,
    as I need it everyday I drove it for a few months until the starting became a chore. Took it in with the receipt and they're suggesting it could be the flywheel, suggesting we investigate - that'll cost me £374.... Which still doesn't answer my question, why didn't it happen before I took it in? is it related?
    Thanks.
    bez101's Avatar
    Jul 2008
    8,510
    no idea without hearing it
    but its gona be hard to blame audi for any wrong doing as you have had it back a few month
    Aug 2013
    6
    That's what i was thinking. I guess the thing is they should get the job right first time, it's not as if we don't need cars. i get the feeling they just don"t care.. about anything but making money. Think I'll be off to an indy soon.
    Pushing the limits..
    Jan 2011
    Australia
    1,316
    Add Sevv on Facebook
    i wouldnt take the car to an audi dealership personally after boding my engine try taking it to awesomegti or something,, its clearly not normal atleast they wont charge you to 'investigate'
    bez101's Avatar
    Jul 2008
    8,510
    tbh if its the flywheel
    doing the belts wont affect it in anyway
    so may be unrelated to the work audi did.
    and iv had it when iv had things done and other things fail at the same time sods law most of the time.
    find a good indi get them to look at it
    Aug 2013
    6
    Bez, Sevv - much appreciated for your time tonight.
    That's what i"ll do tomorrow.
    Cheers.
    27,099
    Ah now its clearer, its, as said, going to be hard to prove much several months later.
    Belt changing can cause starting issues, I suggest you get someone to check the belt & see if out at all, but dealer techies are trained to lock everything of correctly, so I'd be surprised if it is, but hey some tech's don't follow the bible aswell as others.
    I had an issue with starting, moving of etc was a huge problem, with a tech mate it was discovered to be the cambelt fitted badly by selling dealer, new belt, everything locked of & hey presto ran like a dream afterwards.
    Aug 2013
    6
    Thanks NHN, I'll make sure they haven't overlooked the obvious.
    cheers.
    27,099
    Just to clarify, selling dealer wasn't a vag dealer, was a small bunch of tw4ts up in Hull area, its been a good car apart from that but a few little biggles that should not have been present, but indy garages do take the piss at times.
  1. New timing belt kits
    By mattyb6 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th June 2013, 15:16
  2. Help plz had timing belt and water pump and tensioner done now no power!!!
    By ScottScodude30 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th September 2012, 23:50
  3. new timeing belt fitted and still no joy
    By stoneA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th June 2012, 17:08
  4. New Mk1 TT and timing belt
    By zack1uk in forum TT/TT-S/TT-RS Forum
    Last Post: 9th January 2012, 02:54
  5. looking for new timing belt
    By johnsykes in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 28th March 2011, 13:38
