Chris NottAH Fabrications
Like Tree1Likes
  • 1 Post By Johnny Bravo
Thread: aux air heater fault
    tdi-man's Avatar
    Jul 2009
    1,612
    any body help me with this fault
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs /
    233 bhp - 309 ft lb - 419 nm (NEEDS A NEW MAP)
    Johnny Bravo's Avatar
    6+1 Gears
    Jun 2009
    Romania
    797
    I have the same problem. Don't you also have an error on the HVAC module?
    The PTC element is broken. You can either ignore it, buy a new one but is very expensive or find a SH one at the brakers.
    DSG | Vienna Leather | Bose Sound | MFSW | Interior Lights Pack | Light & Rain Sensors | Auto Dimming Mirror Mods: LED RNS-e | FL LED Tail Lights | Bi-Xenons | Illuminated Speaker Grilles | Tinted windows | Chrome Switches | Chrome Paddles&Commands | RS4 Start Button | Cruise Control | S3 Pedals | S3 Roof Spoiler | 18" BBS CH | H&R Spacers 10/15 mm | Bilstein B16 PSS10 | H&R 26/24 ARBs | TT Arms | S3 Front Brakes+DS2500+Tarox F2000 | HEL Brake Lines | VNT20 | EGR&Cooler Delete | Custom Remap
    tdi-man's Avatar
    Jul 2009
    1,612
    where abouts is the part thats broken ?
    any idea on apart number ?
    any pictures of part.
    also could it be any think to do with my head just being done ?
    6+1 Gears
    Jun 2009
    Romania
    797
    It is not related with the engine. Is an electric heater located inside the car, behind the center console.
    I understand that in some cases it could be repaired. You can live with it like that but during cold times you'll only have heat when the engine warms up. This heater is supposed to start giving warm air inside like in 1-2 minutes.
    Also, since it has around 1000 watts (iirc), lowers the MPG during winter
    And be careful, if you want to replace it, buy one with the exact code (D at the end) because depending on that letter their shape is different.
    Mine has an E at the end. I know someone who bought one with an F and had different shape and couldn't install it.
    tdi-man likes this.
  1. Air Con Fault
    By Andy Shipton in forum VCDS (formerly VAG-COM) forum
    Last Post: 24th May 2008, 08:03
  2. Air Con Fault
    By wallacr in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th May 2008, 21:57
  3. Electric auxiliary air heater
    By Amchlolor in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th January 2007, 19:21
  4. Secondary Air System Fault
    By robby in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd July 2005, 19:30
  5. New A3 auxilliary air heater
    By steve184 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th April 2004, 23:38
