aux air heater fault
tdi-man
NULL
any body help me with this fault
20130822 162517
20130822 162546
I have the same problem. Don't you also have an error on the HVAC module?
The PTC element is broken. You can either ignore it, buy a new one but is very expensive or find a SH one at the brakers.
where abouts is the part thats broken ?
any idea on apart number ?
any pictures of part.
also could it be any think to do with my head just being done ?
It is not related with the engine. Is an electric heater located inside the car, behind the center console.
I understand that in some cases it could be repaired. You can live with it like that but during cold times you'll only have heat when the engine warms up. This heater is supposed to start giving warm air inside like in 1-2 minutes.
Also, since it has around 1000 watts (iirc), lowers the MPG during winter :)
And be careful, if you want to replace it, buy one with the exact code (D at the end) because depending on that letter their shape is different.
Mine has an E at the end. I know someone who bought one with an F and had different shape and couldn't install it.
Reactions: tdi-man
