EM TuningSky Insurance
    ARH
    Dec 2012
    117
    Help with diagnostic codes?
    I have had my A3 1.6 FSI for nearly 6 months now and had quite a few problems, the main ones being a rattle on start up and the engine going in to limp mode whilst driving and the EPC light appears (which has only happened two times in 6 months and starts up fine again with no problems) but still, I didn't expect this after paying nearly £7k!
    The car was bought from a dealer in Reading and I'm waiting for a phone call back from him to see what he will do about this, he sold it me with 12 months warranty but I want to see what the dealer says to me first
    The codes:
    6418 - Pressure Sensor for Brake Boost (G294) - sporadic 001-Upper limit exceeded
    5000 - Control Module Malfunction - DBW Throttle Monitouring - sporadic 008-Implausible Signal
    274 - Intake Air Temp Sensor (G42) - sporadic 001-Upper limit Exceeded
    12425 - Singal Line for Fuel Pump Electronics - sporadic 002-Lower Limit Exceeded
    Could anyone tell me what these codes mean, and do any of them relate to EPC light coming on when it goes in to limp mode?
    Aaron
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,343
    What year is your car? Was it scanned with vcds?
    ARH
    Dec 2012
    117
    My car is a 55 plate (facelift) which has just hit 50k
    I got it scanned at a garage will it say what software they used on the report sheet or is it worth ringing them up?
    27,028
    Take the car back & get the wiring checked, fair few issues noted, albeit some maybe old, but needs properly diagnosing.
  1. Need help with Fault codes please
    By xlr8 in forum VCDS (formerly VAG-COM) forum
    Last Post: 10th August 2007, 22:57
  2. Help with this code please...
    By terrymcg in forum VCDS (formerly VAG-COM) forum
    Last Post: 2nd July 2007, 17:28
  3. Help with Fault Code
    By madkebab in forum VCDS (formerly VAG-COM) forum
    Last Post: 23rd February 2006, 13:15
  4. Help with Vag code?00561 - Mixture Adaption limit not reached - Interm
    By imported_ChrisCardiffA3T in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th March 2005, 09:44
  5. HELP WITH VAG CODE! O2 SENSOR?
    By 97AUDIA418TQ in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th February 2004, 12:22
