Chris NottEM Tuning
Thread: Enabling DIS
    Aug 2013
    10
    Enabling DIS
    Could someone tell from my dash if I would be able to retrofit DIS with the correct wiperstalk?
    It has Cruise Control as standard and is a 53plate 2.0fsi.
    The rev counter sticks and zeros itself from where it left off, engine not even running in the pic but if this means I have to get a new cluster is it worth doing the DIS yet? Thanks
    [/URL]
    27,097
    Needs different cluster & you have to be careful which one you fit, has to be coded in probably as immo related, we offer supply/fit services for this, PM if of interest.
  1. Enable dis
    By vwgtiking in forum Retrofit
    Last Post: 11th July 2013, 19:46
  2. Soft Coding to enable DIS
    By B120WNY in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th June 2013, 17:06
  3. VCDS USER NEER Ellesmere port to enable DIS.
    By turricann in forum VCDS (formerly VAG-COM) forum
    Last Post: 15th April 2012, 00:05
  4. Enable DIS on an A3 with S-Tronic/ DSG gearbox
    By nhowroyd in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th October 2008, 21:22
  5. DIS Extender
    By Stormcatcher in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th January 2003, 13:05
