EM TuningMonster Motorsport
    Jun 2013
    Code p0236 please help
    Hi guys first post here I have recently bought a 2004 a3 2.0 tdi. I have full service history.
    It also has had a new turbo fitted and did limp mode for a couple of weeks after but got a sensor put in and now it drives fine.
    my problem now is this code it keeps throwing up even after resetting it.
    the code states p0236 turbo charger / supercharger boost sensor A circuit range / performance.
    Thanks for any help given it is highly appreciated.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Not 100% but i think that is a MAP sensor code, check the wiring or clean the sensor
    Jun 2013
    ok mate I'm a bit of a novice could you please point me in the right direction so I can have ago myself.
    picture would be great, thanks for your reply.
    Vex182's Avatar
    Guess what I drive...
    Apr 2012
    Hinckley
    882
    Add Vex182 on Facebook
    You have a 8p mate? I guess as it's a 2L, might be better to ask them.
    Silver 2002 Audi S3 225 (BAM) since March 2011.
    Mods: Badger5 2.2 TIP, Jetex filter, PCV delete, 710 DV, Standard N249 in use, R-Tech Stage 1 TiV Remap, Audi TT Pedals, Red Dogbone, Polybushed tie arms. All silicone boost pipes, Michelin PS3s, Red V6 coil packs, MK4 flat blade conversion, retrofited cruise control.
    Currently: 254bhp - 276lb/ft (174bhp/ton) as of 11/02/2013 On V-Power
  1. Fault code 17903 please help!!
    By Claire77 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th April 2013, 09:44
  2. Replies: 9
    Last Post: 7th February 2012, 18:20
  3. 9 faults found. Codes inside...Please help!!!
    By DJ_Troopa in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st February 2010, 15:12
  4. VAG error code. Please help.
    By moschino in forum General Technical / How To
    Last Post: 11th April 2006, 20:34
  5. radio codes? please help
    By NxJxHxCedge in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th August 2005, 15:16
