Page 2 of 2 FirstFirst 12
Results 41 to 54 of 54
Like Tree10Likes
Thread: tfsi a bit jerky when cold
  1. #41
    Pushing the limits..
    Jan 2011
    Australia
    1,316
    Add Sevv on Facebook
    Quote Originally Posted by sliced View Post
    Nope not gone, on proper cold weather it is still jerky when its below operating temperature. This is driving me nutssss, any ideas?
    do a carbon clean of your inlet mani and the head on the inlet side.. im quite hopeful the juddering will go away and clean them injectors too just give it ago Sliced .. and you can also delete the flaps on the mani while your at it if you decide to take it off
    sliced likes this.
  3. #42
    TDI140's Avatar
    May 2011
    1,350
    I have this problem on my 2.0tdi if its in a low gear its fine when cold but if i put it in say 4th at 30mph it does it like jerks as if its about to stall but give it some more revs and its fine again, ive had i jectors replaced by audi it seemed to have sorted it though since i added an oil catch can and cleaned all boost hoses so there tight and secure, so i think you should all check boost hoses to see if there loose or have oil in them, my problem is back now again as my jntercooler still has oil build up due to turbo blowing up earlier this year
    A3 2.0TDI FWD sportback with GT1756 250.3bhp 336ft lb, forge boost hoses red, milltek decat system, BMC panel filter, golf gti edition 30 full front brakes brembo pads, black honeycomb grill, full oem s line kit + cupra r lip, LED side lights, OEM xenons, LED interior lighting, LED A8 number plate lights, boost gauge, alloy catch can with red hoses, FBSW, windows tinted, de-badged, now on air ride with chassis notch BBS CH
  4. #43
    TDI140's Avatar
    May 2011
    1,350
    So check the boost hoses and clean them out and report back if it fixes the problem
  5. #44
    sliced's Avatar
    Drive safe, stay alive.
    Jun 2012
    1,210
    Quote Originally Posted by TDI140 View Post
    All hoses checked today, all fine, however checked all the cars hoses and found this in my sisters car!!! ImageUploadedByTapatalk1380472239.752281.jpg
    God knows how she didn't notice driving with a split breather hose
    Current: 8P3 '59 2.0 TFSI 3DR S-Line | Adaptive Bixenons with DLR's | Folding electric mirrors | Heated half leathers |
    Previous : '06 2.0 TDi Sportback in Dolphin Grey| SE | DSG | Satnav | Privacy glass | auto lights | comfort pack |
  6. #45
    sliced's Avatar
    Jun 2012
    1,210
    Quote Originally Posted by Sevv View Post
    Cheers will attempt this next weekend! Fingers crossed
  7. #46
    Jan 2011
    Australia
    1,316
    i hope it will cure it .. i know mine juddered cold or hot and it was due to the inlet and injectors carbon build up so i hope my fix will work for you! btw even 'if' it doesn't fix it ... its preventative maintenance your motor will love you for it
    as for your sister HOLLY S*it thats shocking...women are clueless generally hehe
    sliced likes this.
  8. #47
    sliced's Avatar
    Jun 2012
    1,210
    Update:- scanned with vagcom threw code for P0301-000 misfire detected cylinder 1 - intermittent
    Going to get a new coilpack and get that fitted sometime this week. PS does anyone know which one is cylinder 1?
  9. #48
    Marshy's Avatar
    Nov 2013
    Dumfriesshire
    672
    Cylinder 1 is timing belt side so drivers side of the car.
    sliced likes this.
    IBIS WHITE S3
    Revo stage 2+ and loving it
  10. #49
    sliced's Avatar
    Jun 2012
    1,210
    Quote Originally Posted by Marshy View Post
    so the one ive circled in green is cylinder 1?
  11. #50
    Marshy's Avatar
    Nov 2013
    Dumfriesshire
    672
    Yeah that's it.
    IBIS WHITE S3
  12. #51
    Apr 2011
    12
    I have this 'jerky when cold' symptom as well. It appeared after getting a Shark remap, very noticable on light throttle when cold in 2nd and 3rd between 2500-3000rpm. Changed the plugs and it improved things but it still happens. I've never had any engine lights on the dash, how about you ? Not had VCDS on it yet.
  13. #52
    sliced's Avatar
    Jun 2012
    1,210
    Quote Originally Posted by Scoobaru View Post
    oops forgot to reply, changed the coilpacks and now the problems gone
    CHEZ likes this.
  14. #53
    Jan 2014
    25
    how much did the coil pack cost you/normally cost for a full replacement
  15. #54
    sliced's Avatar
    Jun 2012
    1,210
    Quote Originally Posted by stony2002 View Post
    Think it's about £30 a pop
  1. Internal rattles/creeks when cold!
    By Marko in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th February 2006, 09:11
  2. Hunting/surging at low speeds when cold
    By Eeef in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th November 2005, 17:26
  3. Difficult gear change when cold
    By Kevint in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th September 2005, 19:28
  4. 1997 1.8T 5spd Automatic Gearbod issue when cold?!?!
    By damian_rs in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th March 2005, 17:23
  5. Def. Problem, Car not starting when cold!
    By charTT in forum TT/TT-S/TT-RS Forum
    Last Post: 14th April 2004, 22:10
