Badger5Volks Autos
Results 1 to 33 of 33
Like Tree3Likes
  • 1 Post By Zak0123
  • 1 Post By fangio
  • 1 Post By veeeight
Thread: A3 automatically locks
    slizza786's Avatar
    Aug 2013
    159
    Whenever I unlock the car and it's idle for roughly 20 seconds the car automatically locks which gets abit annoying and my fear is if one day the keys are left inside the car and it automatically locks I'll be screwed. Is there a way to disable this or extend the timer?
    Yonner's Avatar
    Feb 2009
    Oldham
    150
    I think there may be somat in vcds that can disable this , nhn may know what module will need modifying
    leeds2592's Avatar
    When I grow up, I want a 964!
    Apr 2012
    Leeds
    1,180
    Visit leeds2592's Instagram Channel
    Not sure if the timer can be extended but it can be disabled via VCDS.
    Black 2007 2.0 FSI Sport
    2011 Glossy Black RNS-E |AP Coilovers | 18" 7 Spoke OEM BE Alloy Wheels | H&R Trak+ Spacers 8mm (Front) 12mm (Rear) | MY11 Rear Lights | S Line Spoiler | Retrofitted MFSW | Retrofitted Cruise Control | Interior LED Light Pack | OEM LED Numberplate Bulbs
    A3Kent's Avatar
    Different Gear
    May 2012
    1,065
    Just looked at my DIS and it can be changed in there I think. Doors - Lock menu, assuming this is for what you are talking about.
    09 Audi A3 2.0 TDI 170 S-Line SB 8P3
    - Full Leather - LED DRL's - BOSE - Cruise Control - RNS-E Mk2 - AMI - Bluetooth - Folding Mirrors -
    VCDS owner - A3 Grille Install Guide
    slizza786's Avatar
    Aug 2013
    159
    Yh the doors just automatically lock. I'm not really sure with the terminology you guys are using, I'm still quite new to this sorry.
    Zak0123's Avatar
    Apr 2012
    Cambridgeshire
    458
    Quote Originally Posted by slizza786 View Post
    Pretty sure it disables the auto-lock if you open and close the door, meaning that you can't lock your keys inside unless you re-lock it.
    Lima likes this.
    Brilliant Black 61 Plate A3 1.6 TDI
    Mods: S3 BE 5 Spoke Rotor Wheels with Goodyear EfficientGrip
    , AppRadio 2, 80% tints, Diamond Vision Headlights
    slizza786's Avatar
    Aug 2013
    159
    It auto locks even with the trunk open
    Dec 2008
    278
    In short VCDS is a cable\software combination that lets you plug your laptop into the car's ODB2 port and change some coding\settings.
    DIS is Driver Information System - the screen in the middle of your dash where you see MPG etc - there's some menu items that can be changed in there.
    Zak0123's Avatar
    Apr 2012
    Cambridgeshire
    458
    Ok, my bad.
    Mar 2011
    Cleveland
    979
    It won't lock with the keys in. Try it with your spare key!
    slizza786's Avatar
    Aug 2013
    159
    Quote Originally Posted by essIII View Post
    Thank you for that. Am I able to change the auto lock through the DIS?
    Dec 2008
    278
    To be honest, I don't know! A3Kent suggested it's possible - try scrolling through the available options in the DIS using the buttons on the end of the indicator (or windscreen wiper) stalk. I imagine the ability to do this varies depending on the age of the car.
    A3Kent's Avatar
    Different Gear
    May 2012
    1,065
    There is a Door then Lock setting in the DIS as I said before but i'm not sure whether this is for autolock when you reach a certain speed or whether it's for what you are talking about - worth testing.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,475
    so if you unlock your car open the door then close the door
    the car still locks ?
    Lima's Avatar
    AUSmotive.com
    Apr 2009
    Canberra, Australia
    395
    Quote Originally Posted by Zak0123 View Post
    I agree with this.
    However, if you unlock all the doors but only open the boot, I believe as soon as you close the boot all the doors will re-lock. So you could lock your keys in the boot, but if you open one of the main doors the car should remain unlocked until you either lock it yourself or hop in and drive off (assuming you have the lock doors in motion setting activated).
    AUSmotive.com // AUSringers.com
    AUDI: MY10 S3 (8P3) / Nav+AMI / Sunroof / Blackout Grille / RS6 FBMFSW / PSS10s / Milltek TBE / APR HPFP / APR Stage 2+ tune
    slizza786's Avatar
    Aug 2013
    159
    Yh if I leave one of the doors open the car stays open but if I leave the trunk open with all the doors closed the car will lock. Even if one of the windows are open and all the doors are closed the car will auto lock after 20ish seconds and it's just really annoying to have to unlock it with the key again
    Mar 2011
    Cleveland
    979
    It's there so if you accidentally unlock it with the remote (say from in the house) and don't enter it, it will re-lock to stop it getting nicked. You can unlock the boot alone with the middle button with the car locked, then the boot re-locks when you close it.
    A clever system if you ask me, especially if you have your hands full!
    Zak0123's Avatar
    Apr 2012
    Cambridgeshire
    458
    Also you cannot 'lock' the car with the drivers door open, but you CAN 'lock' the car with the passenger door open so that when its eventually closed the car locks itself fully (similar to the boot method), again very useful at times.. or not however you look at it!
    Jul 2013
    39
    We found this out the hard way my partner was setting up the pram placed her keys and mobile in the boot with the car unlocked she then closed the boot without realising and then it locked luckily she was at my mums and was able to wait on me finishing work
    craigynett's Avatar
    Apr 2006
    in a nice small & quiet village on outskirts of huddersfield!!
    300
    Add craigynett on Google+
    Quote Originally Posted by fangio View Post
    somebody i know unlocked their car, got in, put keys in ignition then realised he'd left his walet in the house so got out of the car & shut the door. The doors locked with his keys in the ignition & he only had the 1 key
    Please contact Admin if you wish to advertise your business/services on the forum
    Beagles's Avatar
    Apr 2012
    Cornwall
    88
    Does the key have to be in the ignition? If I throw a key in the boot an close it it locks!
    Mar 2011
    Cleveland
    979
    Quote Originally Posted by craigynett View Post
    Then it's faulty!
    hendry10 likes this.
    MacrosTheBlack's Avatar
    Mar 2008
    Kent
    204
    Yep as people are saying when its working properly it will auto lock the doors, after about 30 seconds, if you have unlocked and then not opened any doors (excludes boot).
    On facelift models roughly 58 plate onwards you can change auto lock functions through the DIS by ticking or unticking options using the controls on the end of the wiper stalk.
    Older models like my 08 prefacelift you need to use VCDS.
    Also car should auto lock the doors once you start driving when you get to 15mph. This then helps prevent you getting car jacked at traffic lights etc.
    Good systems that make good sense to me!
    Sold:Audi S3 (2008 8P2 with upgrades by NHN)
    Phantom Black
    , Bucket Seats, Sunroof, Parking Sensors, FBMFSW, Armrest Phone Prep, Privacy Glass, ILP, FTW, BOSE, RNSE MkII SDS & AMI, Cruise Control, MY11 Folding/Dimming Mirrors, MY11 Rear Lights, Auto Lights/Wipers
    Mar 2011
    Cleveland
    979
    Only if it's activated. Might have been disabled by a previous owner as mine was.
    slizza786's Avatar
    Aug 2013
    159
    I tested the car today. I unlocked it, went inside then closed the doors with the keys in my hand and after 10-15 seconds the car automatically locked! This is really worrying as I can confirm that leaving the keys in the car by accident after unlocking the car and having all the doors closed will lock the car
    craigynett's Avatar
    Apr 2006
    300
    get a spare key done, if you don't want to pay for a new remote & programming just get a blade cut that will at allow you to unlock the door manually
  28. #27
    Zak0123's Avatar
    Apr 2012
    Cambridgeshire
    458
    This definitely doesn't happen on my 61 plate! What years yours?
  29. #28
    slizza786's Avatar
    Aug 2013
    159
    2004
  30. #29
    Zak0123's Avatar
    Apr 2012
    Cambridgeshire
    458
    Such a weird feature...
  31. #30
    Jul 2012
    Cheshire/N Staffs
    1,303
    Your symptom: Door locks itself when it shouldn't
    Your problem: Mis-aligned, worn or faulty door lock microswitch
    Your solution: Lock microswitch problem / Door-open signal failure / Car may lock you out / May affect other VAG vehicles
    HTH
    Zak0123 likes this.
    S3 8V 3DR DSG ACC ABS ADS AMI ASR ASS DAB DBW DIS DRL EBA EBD EDL EGR EPB EPS ESP GPS LED MFSW MMI PDC PSF RAC SDXC TFSI CO2 EEC OTR WTF OMG
  32. #31
    Mar 2011
    Cleveland
    979
    Didn't happen on my 2004 or 2005.
  33. #32
    slizza786's Avatar
    Aug 2013
    159
    Does it have anything to do with the alarm buttons on the drivers door?
  34. #33
    Jan 2013
    Bolton, UK
    402
    Follow Aidy06 On Twitter Visit Aidy06's Instagram Channel
    Thats to stop your alarm going off if you leave a moving object in the car i.e. dog or kids, you press it and lock the car and it disables the sensors inside
    05 DSG AUDI A3 2.0T FSI BLUEFIN'D
    FULLY REGISTERED VCDS USER
  1. Automatic locking when car is moving
    By banoffee in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd January 2010, 13:05
  2. Should my car lock automaticly?
    By sonnyjim in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd August 2009, 07:32
  3. Automatic Central Door Locking....
    By JohnboyC in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd December 2007, 02:29
  4. enable automatic door locking possible?
    By reise in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th April 2006, 15:00
  5. Automatic locking / unlocking.
    By ajmackie in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th September 2004, 23:28
