Chris NottMonster Motorsport
    Jul 2013
    26
    A nice package arrived...
    Came home to these after work, 50mm H&R springs, now if someone could help me with 2 things...
    1) how do I remove the plastic thing above the front struts for them to be removed
    2) the rear axel seems like it's a 2 parter and my old fabia when replacing the springs only had 1 straight across axel, will there be a difference or is it just raise the car, remove bolts from the bottom of shocks then replace springs?
    Jun 2011
    Greenock
    210
    On mine when I did the front coilovers, I just prized the plastic up enough to get the socket in without fully removing the plastic papanel and on the rear I just jacked the car up and unbolted the swing arm bolt with the help of a second jack. I found that to be the easiest way to get the rear springs out. No spring clamp needed on the back.
    Dec 2012
    231
    +1 on all the above I did exactly the same!
    2010 Condor Grey S3 Sportback S-Tronic. 353bhp 400ft/lb.
    Jul 2013
    41
    Again same as above, and lots of swearing getting the back bolt on top mount (drivers side)
    Jul 2013
    26
    Thanks for the help guys!! Hopefully get them on either Thursday or Friday then will update with some pics
    Jun 2011
    Greenock
    210
    Quote Originally Posted by Dan_Mol View Post
    I agree with that, drivers side was a nightmare compared to passenger side. And plenty swearing lol
  1. Speeding ticket arrived today - nice surprise
    By imported_Smudge973 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd August 2005, 13:18
  2. S4 Cab. Will AmD be doing the same package?
    By 18ME in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th December 2003, 09:17
  3. New S4 Arrived
    By JSYAUDI in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th November 2003, 14:28
  4. nerw baby arrived
    By squigly in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st July 2003, 15:51
  5. New Arrival (BABY!)
    By gtdog in forum General Chat
    Last Post: 28th March 2003, 19:40
