Came home to these after work, 50mm H&R springs, now if someone could help me with 2 things...
1) how do I remove the plastic thing above the front struts for them to be removed
2) the rear axel seems like it's a 2 parter and my old fabia when replacing the springs only had 1 straight across axel, will there be a difference or is it just raise the car, remove bolts from the bottom of shocks then replace springs?
Thanks in advance for any help
