cruise control retrofit
graham-tdi
chelmsford
hi guys
Just wondering how much it costs to retro fit cruise control and what bits you need?
Is it just a stalk and some coding?
Interested as i may get this done in the future.
Graham with respect, research the site before opening a new thread please, its been discussed many times before & its very clear on many threads of what parts are required.
Reactions: MacrosTheBlack
Parts around £100.
Requires coding plus a wire depending on module fitted to car.
Tricky to install if you do not have the right tools.
Coding easy with VCDS
If not sure about handling airbags..best use independent installer. Many on this site who charge a fraction of what Audi would.
You can expect to pay £150-£200 to have it fully fitted
Lower cowling is also needed.
Fitting isn't difficult really and there is a few guides knocking about which make it a lot easier to do. You do need a M12 multi spline bit though to get the steering wheel off.
