EM TuningMonster Motorsport
Results 1 to 39 of 39
Like Tree1Likes
  • 1 Post By JamesS4cab
Thread: TTRS brakes on an S3 fitment guide - INC STD S3 WHEELS
    JamesS4cab's Avatar
    Mar 2008
    1,091
    Given the amount of people that have asked me to help with TTRS brakes and what wheels fit and what dont, i thought i would stick this up so hopefully it will help everyone.
    As you know, I had 4 sets of 19's and below you can see what did and didnt fit over the Rs3 setup
    • 19" BBS CH ET50 8J - FAIL - even with a 11mm spacer. Would need 13mm or 14mm to clear.
    • 19" BE rotors - Et 43 - 8.5J - easy cleared. No spacers
    • 19" Speedline Spits - ET 48 - 8.5J - FAIL even with a 11mm spacer. Would need 13mm or 14mm to clear.
    • 19" MTM Bimotos - ET50 - 8.5J - easy cleared. No spacers
    Std 18" S3 alloys (the earlier shape ones) - FAIL - even with an 11mm spacer - wheel was tight with the caliper. I therefore added a 3mm shim to see if it fitted and it does. There isn't a great deal of clearence and i wouldnt drop to 13mm overall as i wouldnt be comfortable with that.
    THE ONE KEY POINT TO NOTE IS THAT YOU CANNOT HAVE WHEEL WEIGHTS ON THE OUTSIDE EDGE ON THE INNER BARREL AS THEY SIMPLE WILL NOT CLEAR THE CALLIPER. THIS IS A BIG PROBLEM IF YOU DONT HAVE A PAIR WHEELS WITH NO WEIGHT.
    When I turned the wheel, the weights jammed on the caliper - end of. No go.
    Overall fitment with 14mm spacer/shim combo is good - wheels don't run on the arches even with 25mm H&R lowering springs and they are pretty much flush.
    I'm not smart enought to calculate what offset/width combo does and doesnt fit as i think its more to do with the design and shape of the rear of the wheels. But i could be wrong.......
    Hope this helps people.
    Dean_T likes this.
    "Dont get me wrong. Ugly girls need loving. Just not by me."
    VAG_BADGER's Avatar
    Ricers in the rear view!
    Jan 2011
    Sheffield
    71
    Quote Originally Posted by JamesS4cab View Post
    Hi James,
    I've just been through the whole trial & error side of fitting the TTRS setup. I polished up the discs and just had to have them on! Long story short there are no 18" OE wheels that will fit. The rotors will clear but only with a 14mm spacer which is just not feasible. Funnily enough though 18" replica rotors fit with a 5mm spacer! I had to go 18" as I just bought 4 new tyres and am a little unsure about 19's on the A3 platform.
    In the end I went for the lightweight 18x8 ET45 Team Dynamics Pro Race 1.2's. Great wheel being strong and light, sounds like a bell when you clang them! Just like OE. Designed to accommodate big brakes to start with they were an easy fitment, actually cleared with no spacer but opted for a 5mm hubcentric to be safe. A 3mm would have done it easily but I had the 5's to hand.
    Anyway, just a quick question regarding the brake lines. Did you opt for the correct OE lines or straighten out the S3 ones? I'm a little torn at the moment for which to go for as the right ones are expensive. I take it you just straighten out the first very acute bend until it all fits?!
    Thanks!
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,386
    Quote Originally Posted by VAG_BADGER View Post
    Hi James,
    Thanks!
    my mechanic made oem s3 lines to fit. i think they need to bend slightly for corect fitment. that's whats done to mine.
    also my oem facelift wheels clear the brakes with 12mm spacers that i had on for ages, and there is about 5-6 mm clearance due to spoke design.
    here's pic of mine setup:
    s3 Ibis White ... Build Thread
    / Black Grill / FbMfSw / Sunroof / Hill Hold / Armrest / Black Leather-Alcantara interior / Rear Parking Sensors / Heated Seats / Folding Mirrors / Cruise / Rns-e mk2 // ttrs-Brembo Brakes / 12mm spacers / Forge Short + Side Shift / 42dd's / ITG CAI / GfB DV+ / Forge Catch Can / Milltek TBE / Forge Twin IC/ Autotech HpFp / H&R ARB's / WALK / KW v3's / RS4 fpr / Loba&Sachs clutch / Revo Stage 2+ / ...
    turbonutz's Avatar
    Jul 2013
    Glasgow
    393
    are people confusing the ttrs and rs3 disks here? i heard that ttrs fit wth bit of spacing with old style oem wheels where as rs3 disks need crazy spacers?
    Pre-facelift Sprint blue Audi S3 8P with Shark Stage 3, H&R Anti roll bars, BCS Sport turboback, ITG air intake , Autotech HPFP internals, Titanium Powdercoated OEM wheels LED interior Pack LED bulbs:
    Soon to be added AP X coilovers Porsche 996 Brembo brakes with Brembo X-drilled disks (Still!!)
    On hunt for engine mounts and O.Z Superturismo LMs(Maybe)
    VAG_BADGER's Avatar
    Jan 2011
    Sheffield
    71
    Quote Originally Posted by turbonutz View Post
    Im talking spacing the wheel from the disc to clear the caliper. I think you mean spacing the disc from the back to essentially reduce the offset. The RS3 has different hubs & bearings to the S3 which suit a bigger offset disc which won't line up with the caliper when fitted. No idea why the TT set up was designed differently but it's the same set up as an S3 which is why the TTRS kit bolts straight on.
    I've seen the standard facelift 10 spokes fitted over the TTRS set up before down at statllers in Sheffield. IMO a 24mm track increase is just too much for the tolerance of the ackermann steering geometry, not to mention the extended load on the wheel bearings.
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,386
    it's like fitting the wheels with lower offset. doubt that makes much difference. i've been driving with spacers on the front for ages now...
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,155
    To combat this, would it not be recommended to increase to a 8/8.5 inch wheel with a smaller offset to clear the calipers, instead of using spacers? Even though you are increasing the track, with the width of the new rim being larger sitting at the same inset, I assume that there would not be any increased load to the bearings and only a slightly increase on load of the steering geometry?
    Audi history... Brilliant Red 2.0tfsi Quattro, Sprint Blue S3...
    turbonutz's Avatar
    Jul 2013
    Glasgow
    393
    hmmmm i dont know what to do. want said brakes, dont want to change wheels till atleast after christmas, spacers cost a good bit to. ma disks are lipping aswell and really could do with changing but imo would be a waste as not wanting to keep them long hmmmm
    VAG_BADGER's Avatar
    Jan 2011
    Sheffield
    71
    Quote Originally Posted by S3_Jacko View Post
    It's a fair point yes. The wheels I went for were 18x8 ET45 which are actually already pretty close to touching the suspension leg. From my experience in the quest for wheels, 18" ones anyway, it was more the shape of the spokes and the shape on the inner part of the wheel where the caliper runs that was the issue. As I said the wheels I have actually fit with no spacer but only leave a playing card gap from the inner edge of the caliper so I opted for the spacers for safety more than anything. If you went for a lower offset I think this would reduce the swooping angle of the spokes which defeats the object? I'm no pro on wheels which is why I went the trial and error route! (3 sets of wheels later!!!)
    VAG_BADGER's Avatar
    Jan 2011
    Sheffield
    71
    I did it because the car is now running just over 360bhp and the brake fade was becoming much worse on hard runs. I also did it because they look the dogs, especially after I mirror polished the disc inners! I wouldn't swap them simply for that lol! I do have a spare pair of calipers though if anyone requires!!
    turbonutz's Avatar
    Jul 2013
    Glasgow
    393
    that must have cost a bit eh badger :P
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,155
    Yeah I know exactly what you mean... more the shape of the spoke design that really causes the issue.. not so much on a larger wheel though, because any wheel with a smaller offset usually allows for the spoke to sweep to the outer edge of the rim, unless they are deepdish of course... 18's would cause issues with the inner rim, 19's not so much....
    VAG_BADGER's Avatar
    Jan 2011
    Sheffield
    71
    Yeah exactly. The majority of 19" wheels fit. I did fancy the 19" rotors but I had 4 brand new p-zeros to use up which dictated 18". Still have a set of 18" genuine rotors I bought that sadly didn't fit. Couldn't get them to fit at all, even with a huge spacer the shape of the inner dish touched the face of the caliper. I could have milled a flat face on the calipers where they touched but in the end I felt the right route was the TD 1.2 pro race wheels. Heard nothing but good things for quality and clearance with big brake setups. I can't praise them enough, such great quality and strength as well as saving me a couple of kilos per corner, they literally weigh nothing (8kg).
    VAG_BADGER's Avatar
    Jan 2011
    Sheffield
    71
    I wouldn't like to have an add up but on the plus side I've given below market value for the majority of items bought for the car. I like shopping around for bargains!
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,155
    and saving you a fortune on tyres
    larsmate's Avatar
    Apr 2004
    111
    Nice work jamesS4cab.
    Can anyone offer an opinion on whether OEM RS3 rotors will fit (19" 8j ET50) around TTRS disk and caliper setup? I note jamesS4cab says he's tried BBS with same specs which don't fit.
    Black S3 | MY09 | APR 3.1 Stage 2+ | RNS-E Mk2 | Tints | Titaniums | APR DP | APR HPFP | WALK | H&R SPRINGS | Lamin-X | BlueVAG VAG-Check |
    turbonutz's Avatar
    Jul 2013
    Glasgow
    393
    Quote Originally Posted by larsmate View Post
    well... they are rs3 brakes, and rs3 wheels
    larsmate's Avatar
    Apr 2004
    111
    Well..... they are TTRS brakes and RS3 wheels. RS3 brakes as per earlier post don't fit the S3 hub while TTRS brakes bolt straight on.
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,155
    I'm pretty sure the hubs the same offset though.. and I dont think there will be any issues with 19's... are 19's not the upgraded RS3 wheel?
    larsmate's Avatar
    Apr 2004
    111
    Not sure what you mean "upgraded"? I have standard OEM RS3 rotor wheels (19" ET50).
    Also I'm a bit confused with the OP's first post as the subject is "TTRS brakes on an S3 fitment guide" but first line says RS3 not TTRS - "As you know, I had 4 sets of 19's and below you can see what did and didnt fit over the Rs3 setup"
    Bottom line is will these fit my S3? - Original Audi TTRS RS3 Golf GTI R32 Brembo Bremse Bremssattel+Beläge+Scheiben | eBay
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,386
    mate that's ttrs setup. 8j0 part numbers are from ttrs. that's whats on my car right now. so it should fit.
    rs3 discs are part number with 8p0.
    VAG_BADGER's Avatar
    Jan 2011
    Sheffield
    71
    Quote Originally Posted by S. View Post
    If you look at the picture, the p/n number on the disc is actually 8P0!! Buyer beware eh!
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,386
    Ah soo. Was looking on the phone so didn't see no. On the pic., description says 8j0 so i was going by that.
    You can always contact seller and ask him the part no. Of the parts, as those might not be the actual pics.
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,155
    Ahhh just re-read your comment... its the 8.5j 19's thats the optional upgrade for the Rs3.... well the BBS CH's are the same size and it looked liked he had issues with them...
    turbonutz's Avatar
    Jul 2013
    Glasgow
    393
    ^ no issues with them u mean?
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,155
    Edited... wrong wheels... ha
    What I meant was that the BBS CH's are the same size and fitment as the RS3 wheels, but it looks like they did not work... but the Rotors might have a different spoke dimension... but reading the original post again.. i'm also a little confused as to what caliper setup this is actually for?
  28. #27
    ilim's Avatar
    Nov 2011
    631
    Doea anyone know if TTRs BBK will fit bbs 19 ck with et45?
  29. #28
    Jun 2013
    10
    +1 for TD Pro Race 1.2 It's what I have on mine over the TTRS BBK setup too. Great wheels and I think the Multi-spoke look works great on the S3 8P IMHO.
  30. #29
    JamesS4cab's Avatar
    Mar 2008
    1,091
    Can confirm that any 19" rotors should fit with no problems. The a4 BE ones i had had well over 1" of clearance due to the shape of the rear of the blades. Even the 18's i tried would have fitted from the rear of the blades to the face of the caliper. The piece, as i think badger says is the barrel of the wheel catching on the front of the caliper.
    The Rs3 discs will fit but you will need a bracket for the caliper carrier to line up with the disc as the offset of the bell is different to the TTRS. The discs I am using have a part number of 8J and fit with no problems and no messing about with brackets for the carriers. Straight fit - (other than adjusting the std S3 lines a tad).
    TD's 1.2 18's are fine - as long as if you need to balance the wheel with any outer lip weight, this is done in the centre of the barrel - the same as std s3 8P1 and 2's as i have tried all of the above as well. If you try and balance to the outside of the rim (as in the outside of the barrel behind the spokes, the weights will catch on the caliper and simply rip off. Been there - done that!
  31. #30
    zyzio's Avatar
    Feb 2011
    19
    BBS CH-R 8,5J x 19 with ET40, not fit, need 3-4mm spacer.
  32. #31
    zyzio's Avatar
    Feb 2011
    19
    At my brand new BBS CH-R 8,5j x 19 ET40 with 225/35 tire the clearance fixed using 5mm spacer, I think 4mm should be enough. I hope it woudn't be rub. It looks very similar to my BBS CH 18"x8 ET50 + 13mm spacer at front. No rubbing issue as well.
  33. #32
    Feb 2014
    30
    i have bbs lm's 19'' what size wheel spacers do you recomend 15mm ?
  34. #33
    Mar 2014
    23
    Hi I'm new to this site. Recently bought an s3 and done my homework and bought some brakes from a ttrs. Busy looking for some 19inch wheels as my facelift 18s need a 12mm spacer and worried about weights on wheels catching in future when tyres need changing.
    Seen some 19inch rotors for sale 19x8.5J ET45.
    Anyone know if these would fit?
  35. #34
    XFi
    XFi's Avatar
    Jun 2010
    Grantham, Lincolnshire
    313
    Add XFi on Facebook Visit XFi's Youtube Channel
    Those with TTRS/RS3 calipers what pads are you using?
    I need to decide if I stick to Brembo pads with anti-squeal or go for something like Pagid blue.
    Audi S3 8P3 Stage 1
  36. #35
    Mar 2014
    23
    I currently have standard pads. Was going to go for yellow stuff as seen Revolutions write up on them on their rs3. Still undecided though, I may go for some brembo pads I've seen.
  37. #36
    Apr 2012
    491
    I no its a old thread Im running 9.5j on the front of my Audi a3 2004 will the rs3 fit easier w ity wider wheel and less offset ?
    Et30
  38. #37
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,386
    it should? how can you run 9.5j with et30 on a3? did you do something with fenders?
  39. #38
    Apr 2012
    491
    Nope fit fine running 215/35/18 Tyers
  40. #39
    Apr 2012
    491
  1. My new R32 brakes and M8s 19" with TTrs Brakes
    By tdi-man in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th April 2011, 07:58
  2. Wheel fitment guide?
    By antnee in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd January 2011, 23:34
  3. S3 rear suspension bush fitment guide?
    By S3Steve in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd April 2010, 17:30
  4. Ebay Fmic Fitment guide
    By Plunky in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th August 2009, 16:26
  5. Alloy Wheel Fitment Guide
    By T11OM F in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th October 2007, 19:25
