Sky InsuranceVolks Autos
Results 1 to 10 of 10
Thread: Rear camber
    May 2013
    7
    Rear camber
    Hi,
    What's the best way of adding rear camber, already at 3 degree on the rear camber arm but need to add some more. Can't find any camber shims for the 8p.
    any ideas?
    cheers
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,370
    Quote Originally Posted by Ryan94 View Post
    Hi,
    any ideas?
    cheers
    Why add more camber?
    You really shouldn't need more than that,and even mine doesn't need more.
    May 2013
    7
    Will be running 9.5j et18 so I reckon I'll need to be running about 5 degree to be safe
    TDI140's Avatar
    May 2011
    1,355
    Holyyyy s*** ET18 with 9.5J thats crazy please post pics also 19" ? Or 18" ?
    A3 2.0TDI FWD sportback with GT1756 250.3bhp 336ft lb, forge boost hoses red, milltek decat system, BMC panel filter, golf gti edition 30 full front brakes brembo pads, black honeycomb grill, full oem s line kit + cupra r lip, LED side lights, OEM xenons, LED interior lighting, LED A8 number plate lights, boost gauge, alloy catch can with red hoses, FBSW, windows tinted, de-badged, now on air ride with chassis notch BBS CH
    May 2013
    7
    18in, there porsche eta beta krone splits with 30mm spacers. Should look decent when set up right, I know it'll be terrible to drive before anyone says
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,370
    Well....that's what I was about to say but if you're doing this for looks,then you know what you'll get.
    5degrees is way beyond what's good and the tyre wear will be interesting.
    TDI140's Avatar
    May 2011
    1,355
    Im scared to run ET35 lol dropping down to ET45 with smaller adaptors lol but would love to see pics mate
    May 2013
    7
    I'll get some photos up when it's done, currently running 19in 8.5j et35 so it'll be interesting for sure
    May 2013
    7
    Anyone got any ideas on the camber?
    May 2013
    7
    Bump
  1. Wheel Alignment for Rear Camber
    By jomnhta in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th March 2008, 20:44
  2. rear camber with damaged shock?
    By aidank1981 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th March 2007, 08:30
  3. Rear Camber Problem Adjustable bush kit!!!
    By 242spot in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th December 2006, 21:31
  4. Adjusting Rear Camber / Toe on S3 !
    By darko in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th April 2006, 21:43
  5. Lowered S3 on H&R springs-Rear Camber
    By keendean in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th April 2006, 22:52
