Chris NottSky Insurance
    Jul 2013
    36
    A3 halogen drl upgrade
    Hi apologies if this has been asked before I had a search but couldn't find anything anyway my sister in law has a 2010 white a3 1.6tdi 3dr and she asked me about replacing her standard halogen drls with led bulbs so I was just wondering if this is possible without showing an error on the dash and also which type of bulbs I would need thanks in advance
    Reload's Avatar
    Bird is the Word!
    Jul 2010
    Midlands
    364
    Speak to t8ups on here, hes the resident expert on all things LED. He can supply the bulbs you need as he did for me which look great. The car will require a quick bit of VAGCOM coding to remove the bulb out warning though.
    S3 8P2 Ice Silver, RNS-E, Bluetooth, iPod connection, Adaptive xenons, black styling pack, sunroof, privacy glass
    Mods since owned: Milltek Resonated TBE, Neuspeed P-Flo, Loba HPFP, Sachs Clutch with Loba SMF, Unicorn Motor Developments custom remap, brakes + suspension upgrades, LEDs internal and external, more interior kit
    Jul 2013
    36
    Thanks for the reply I'll send him a pm i'am not too sure what vagcom is i'am also after led number plate lights too
    26,776
    VCDS is the diagnostic system for vag cars.
    Only if your car supports led coding will this be possible otherwise its using the correct resistance led pcb's or resistors in line which I don't recommend as they get warm & can affect surrounding plastics.
    Chat with t8ups.
    Reload's Avatar
    Bird is the Word!
    Jul 2010
    Midlands
    364
    Chat with t8ups.
    Agreed, an MY10 car should support LED coding. T8ups can supply the LED number plate bulbs too.
    Jul 2013
    36
    Hi thanks for your help I will go and send him a pm now
  1. GROUPBUY: - Canbus LED bulbs to replace halogen DRL bulbs
    By andi1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th February 2013, 23:38
  2. Bulbs to replace Halogen DRL
    By Ash187 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th November 2012, 23:36
  3. change halogen DRL bulb?
    By sting3r in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th November 2011, 20:33
  4. HALOGEN DRL's - NEW BULBS FITTED!!!!!!
    By J8Y PW in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th May 2011, 20:00
  5. 2010 drl upgrade
    By fordfitzsimmons in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd March 2011, 09:50
