EM TuningBadger5
    Jan 2013
    Edinburgh, Scotland
    61
    Help with Aerial problems.
    I have recently replaced my concert head unit in my 2006 A3 with an aftermarket kenwood unit. The problem i am having is the rear speakers seem a little quiet, and the radio reception is rubbish! Every thread on here points towards an aerial booster adaper which i already have installed, so I am looking for a little extra help.
    I have currently installed:
    Harness PC9-401 (I believe my system is half amped, although this harness leaves the rear speakers very quiet and a little crackly.)
    and Aerial adapter PC5-137 (This uses the Fakra connection but leaves me unsure what to do with the ISO aerial connection, if anything?)
    I have managed to overcome the volume difference in the front and rear speakers using the channel balancing feature, reducing the volume in the fronts, and using a slightly rear biased fader setting, but doesnt eliminate the slight crackle.
    The aerial adapter I have tried connecting the blue remote wire to the amp remote, and a 12v feed, which both give poor results.
    Have I missed anything? or is there anything i can try/check?
    I don't normally listen to the radio other than for the odd traffic report, but having thought i wouldn't miss it if it wasn't there, It's getting kind of annoying!
    Thanks!
    Brodster's Avatar
    Shark Performance In Scotland
    Mar 2011
    Scottish Borders
    3,402
    Follow Brodster On Twitter Add Brodster on Facebook
    I think NHN will be able to answer this David. You coming to the meet on the 31st?
    Angelwax/BBS/BCS/Bilstein/Cobra/CTS Turbo/DTUK/H&R/K-Sport/KW/Loba/Milltek/Shark Performance/Oz Racing/TPI/VCDS/V-Maxx/Vossen/Wagner
    Jan 2013
    Edinburgh, Scotland
    61
    I hope so, It's getting annoying!
    What sort of time will things be happening? I'll no doubt be working until 6, so if it will be a daytime thing i probably wont make it
    Jan 2013
    Edinburgh, Scotland
    61
    Anybody got any ideas? I've tried everything I can think of!
    Mar 2012
    369
    I know what's wrong, but not the answer sadly. As I understand it, the Fakra connection is simply to help the audi head unit decide which of the diversity aerials has the strongest signal - and the actual signal is piped down the ISO so you really need both - but not sure if there's an adapter that caters for that. I went DAB with a screen mounted aerial instead. The quiet rears was a problem I also had, caused by the fact that the front output from my replacement HU was so much louder and clearer. All I could do was "stagger" the F-R fade with a rear bias to balance it out. If your HU has a setting for the output level from pre-amp, you could try jacking that up a bit.
    Jan 2013
    Edinburgh, Scotland
    61
    Quote Originally Posted by JohnE View Post
    I know there is a dual Fakra adapter which could be fitted with a few other adapters, but i don't think it would help as the kenwood unit won't differentiate between aerials i assume...?
    There is a channel adjustment option on the headunit so i have the fronts reduced to -8dB and a little rear bias from the fadar to even it out, but the crackle is still audible when music is turned down.
  1. Help with MAF problem please??
    By sherry in forum A6/S6/Allroad forum (C6 Chassis)
    Last Post: 10th September 2012, 07:16
  2. Help with paint problem please
    By paddy in forum Detailing
    Last Post: 13th February 2011, 11:36
  3. Need your help with a problem!
    By Mr.G in forum TT/TT-S/TT-RS Forum
    Last Post: 10th July 2010, 18:07
  4. Help With Some Problems With The Car
    By emzino in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th September 2008, 21:35
  5. HELP with Timing Problem!!
    By imported_alex100a in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 31st March 2005, 01:32
