AH FabricationsEM Tuning
Results 1 to 15 of 15
    Dec 2012
    chelmsford
    29
    Possible wheel bearing?
    Hey guys
    i have started getting a sorta wop noise coming from the rear left of the car any ideas why it could be??
    car is front wheel drive.
    cheers
    26,720
    3 or 5dr?
    Dec 2012
    chelmsford
    29
    26,720
    Well stone guards are a good one for noise on 5dr's, but wheel bearings are another, ideally lift & turn the wheel.
    DomH's Avatar
    Jun 2013
    Leeds
    104
    Check for distortion on the inside edge of the tyre, will feel like a 50p piece and can give a similar noise to a faulty bearing
    Dec 2012
    chelmsford
    29
    if the brake pads are low could this have the same affect?
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,758
    No unless the noise is there only when braking.
    I had a similar noise and it was the tyre, I move the wheel to the front and the noise travelled with the wheel.
    leeds2592's Avatar
    Apr 2012
    Leeds
    996
    When my wheel bearing was knackered, it constantly made a 'vvvrrrrr' sound which got worse when I turned a corner. Best way to check if it's the wheel bearing is jacking the car up and looking for play in the wheel.
    Black 2007 2.0 FSI Sport
    2011 Glossy Black RNS-E |AP Coilovers | 18" 7 Spoke OEM BE Alloy Wheels | H&R Trak+ Spacers 8mm (Front) 12mm (Rear) | MY11 Rear Lights | S Line Spoiler | Retrofitted MFSW | Retrofitted Cruise Control | Interior LED Light Pack | OEM LED Numberplate Bulbs
    Dec 2012
    chelmsford
    29
    The other thing is there is no play in the wheels? Is there anything else which coulda or this sound??
    DomH's Avatar
    Jun 2013
    Leeds
    104
    A good way to test for a bearing noise is when driving, find yourself a nice empty road and gently turn left then right as if you are doing a slalom, the noise should get louder turning one way as you are putting more loads on those bearings. So if I becomes louder when you turn to the left, you know it's an O/S bearing, and to the right, it's N/S
    Danny-boy's Avatar
    Jan 2013
    477
    Quote Originally Posted by DomH View Post
    How do you tell it is front or back?
    I have a drivers side bearing gone but can't tell if it's front or rear.
    DomH's Avatar
    Jun 2013
    Leeds
    104
    Quote Originally Posted by Danny-boy View Post
    Sorry should of said it's not the best method for telling whether it's front or back, more just which side! Best way is to get the drivers side wheels off the ground and give them a spin, then listen to each wheel as it's spinning, you should be able to tell straight away as it will be all crunchy
    Danny-boy's Avatar
    Jan 2013
    477
    This is my issue, grabbed the wheel and no play, rotation sounds ok on all 4.
    Not sure how much a bearing change is, but I want to get the right one!!!
    DomH's Avatar
    Jun 2013
    Leeds
    104
    Dodgy tyre then?
    Dec 2012
    chelmsford
    29
    Took the car into audi today and they replace both rear wheel bearings.
    Glad ive got warranty on the car or it would've cost me £500
  1. Can anyone help - possible wheel bearing failing.
    By Harribo66 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st March 2013, 19:01
  2. High pitch sqweal when turning right......... Possibly wheel bearing?
    By Dani_B19 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th February 2013, 19:30
  3. 95 Cabrio - Possible Wheel/Tire Combos
    By jhreid2 in forum Classic Audi Forum
    Last Post: 16th May 2004, 20:05
  4. Wheel Bearing (Spelling?) noisy
    By dickys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th April 2004, 17:34
  5. Funny noises from my S3 (Wheel bearings?)
    By comdw in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th September 2003, 09:45
